Old 04-09-2008, 11:10 AM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
How long can we leave the car running?
For conserving gas, did you ever hear about letting your car idle for a short time insead of turning it off? Because it takes more gas to start it up. How long is too much, it take for it to idle using more gas than a startup? Making it not worth to leave the 3.3 running.
If you can understand this. For loss of better wording.
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 04-09-2008, 11:18 AM
~*~JenSVX~*~'s Avatar
~*~JenSVX~*~ ~*~JenSVX~*~ is offline
J. Bond
Send a message via AIM to ~*~JenSVX~*~
I left my car running while I was at work once for 5 hours... I don't think that saved gas though..
J. Bond 7
1994 Laguna Blue
www.longislandsubaruclub.com
LISC member #50
Old 04-09-2008, 11:34 AM
crazyhorse's Avatar
242,000 mi on oem trans
My thoughts would be, that if it's less than 30 seconds or so, leaving it running, would be a fuel saver. For 30sec, or more, it's more efficent to turn the car off.
"42"
Current Stable By Age:
Old 04-09-2008, 02:25 PM
Manarius's Avatar
Manarius Manarius is offline
I don't see why it would take anymore gas to startup than it would to run the car. This isn't 1960. We have fuel injection now. I turn off my car if I'm sitting at a stoplight for longer than 15 seconds.
-Jason
-Obi Wan Kenobi
Old 04-09-2008, 05:21 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Why do truckers leave their diesel engines running whe parked? Not related to that question, I'll leave mine running for short periods because I think it's easier on the car than running through the cycle of start up. Does that make sense? 5 hours? That's stretching it. Did someone lock the keys in the car?
Gene
Gene and Ben
Old 04-09-2008, 05:23 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
Somehow I vision you going through starters like a pack of chewing gum....
1994 subaru svx le 112k
Old 04-09-2008, 08:27 PM
I would not turn it off unless it was going to be more than a couple of minutes - like at a long light. Your starter is going to wear out if you stop the car every couple of minutes.
Old 04-09-2008, 08:31 PM
I never shut my car off on the road. You never know, my car's been reliable, but there's always a chance it won't start up again.
Drivers of turbo'd cars are told to let the car idle for a minute or two after a spirited drive so the coolant can pull some heat away from the turbo and prevent severe heat soak/damage/expensive badness. That's what a turbo timer is all about, it will keep the car running for a minute or so after you remove the key.
Old 04-09-2008, 08:39 PM
J. Bond
Gene
Nope, door was wide open... SVX idles too low. I didn't even know it was running till the end of my shift when I went to get my keys and they were missing... Then I checked the car and even after walking up to it didn't realize it was running until I opened the door....
J. Bond 7
1994 Laguna Blue
LISC member #50
Old 04-09-2008, 08:56 PM
Are you blonde? (sorry just had to say it, I know you aren't)
blk 92' LSL w/ average mods
Old 04-09-2008, 09:00 PM
J. Bond
haha no.... Definitely a blond moment though... It was a stressful day of my life... First day back to work after a 3yr relationship break up... Now at least I can smile about it though, silly moment that nothing mechanically wrong came from...
J. Bond 7
1994 Laguna Blue
LISC member #50
Old 04-09-2008, 09:03 PM
cool, glad you didn't take it the wrong way
Old 04-09-2008, 09:17 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
Gene
I know in the winter it's to keep the heat going. Other than that I haven't a clue. I'll ask my father when he gets back from wherever he is. He's a trucker.
Old 04-09-2008, 11:11 PM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
There are several reasons that over the road truckers idle their vehicles while parked and or even sleeping.
  • Diesels are hard to start when cold. The fuel in diesel engines is fully ignited by nothing more than heat of compression. Therefore cold motor, harder to start.
  • Diesel motors do not have throttle butterflies. The intake system is wide open minus turbo compressor if the engine is turbo charged. This means the engine has no restriction sucking in air. A gasoline engine has throttle butterflies that act like a valve to meter the amount of air entering the engine (thusly the sucking sound you hear if you open your air box). This type of design actually chokes the engine at idle and actually reduces efficiency. To visualize this imagine two large syringe like turkey basters. Mark one as gasoline the other as diesel. On the tip of the gas one, put a reducer that will only allow about 10 percent of the air in. On the other, leave it wide open. Pull the handles to suck in air. This was the intake stroke on both engines. What engine labored less to idle? The diesel.
  • The lubrication system on a large diesel engine is many times more complex then a gas motor. In principal, the roles are the same, but in the larger diesel motor, the oil has to travel UP and THROUGH much more distances and from a cold start, it can take time before all the parts become pressurized with oil. Start ups are where most of the wear in all internal combustion engine take place (barring physical damage).
  • Due to the insane compression ratios used but diesel engines, the starters require much more torque and energy to turn over the engine for starting. This is taxing on the starter and electrical system. Diesel starters typically cost 3x or more than a standard gasoline engine starter.
  • Lastly, the drivers do like residual heat in their cabs while they nap
Hope this helps
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 04-09-2008, 11:19 PM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
If it was my svx, the doors would have automatically locked behind me... i've had friends learn that the hard way.
Marisa
