Old 01-08-2011, 02:25 PM
Cam Cam is offline
Exhaust Manifold torque
So I am completing my build, putting the exhaust back on, and need to know the torque for the nuts that mount the exhaust to the heads, and the bolts that mount the secondary pipes onto the manifold. I looked everywhere but I never have luck with the search function here. Thanks guys.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 01-08-2011, 03:03 PM
Old Fogey
Re: Exhaust Manifold torque
Manifold to head is 25-33 ft-lb
Exhaust to manifold is 22-29 ft-lb
Glenn
Old 01-08-2011, 03:19 PM
Cam Cam is offline
Glenn
Much appreciated.
Cam
'92 Ls-L Dark Teal
Old 01-08-2011, 03:32 PM
I have this list tacked to the shop wall.
Since you already have the answer this could not hurt.
http://www.subaru-svx.net/photos/fil...iles/44342.doc
Old 01-08-2011, 03:54 PM
Old Fogey
Originally Posted by Cam View Post
Much appreciated.
My pleasure Cam. My FSMs are always next to the PC. Thank you svxfiles, that's a handy reference!
Glenn
Old 01-08-2011, 07:02 PM
Cam Cam is offline
Glenn, would you happen to have the torque values for the engine mounts to the block, and the bushings to the mounts? Also the bushings to the crossmember? I really need to get some FSM's.
Cam
'92 Ls-L Dark Teal
Old 01-08-2011, 09:59 PM
Old Fogey
Sure Cam,
Front engine mounting bracket to block is 14-25 ft-lb.
Cushion rubber to X-member is 40-61 ft-lb
Cushion rubber to mounting bracket is 36-51 ft-lb
Hope that helps!
Glenn
Old 01-08-2011, 10:03 PM
Cam Cam is offline
Sure Cam,
Hope that helps!
Glenn
Tons! thanks a lot.
Cam
'92 Ls-L Dark Teal
Old 01-08-2011, 10:05 PM
Old Fogey
Cool!! Good luck with the project!
Glenn
