Old 08-08-2012, 02:46 PM
THE NEW GUY THE NEW GUY is offline
how does the ecu determine the load on the engine?
I understant that in newer models, subaru installs a vaccum sensor to determine the load on the motor so the ECU can control more effectivelly the ignition time, but our SVX does not have a vaccum sensor... does it?
Old 08-08-2012, 02:49 PM
Re: how does the ecu determine the load on the engine?
No. It uses the Mass air flow sensor to meter the amount of air the engine takes in.
'92 SVX LS Pearl White - 6mt
Old 08-08-2012, 02:51 PM
Combination of throttle position sensor, RPM, MAF, probably the O2's as well... A lot of factors show how hard the engine is working.
Old 08-08-2012, 05:55 PM
oab_au oab_au is offline
I am not too sure that is right. The latter ECU use the atmos sensor to change the gearbox maps, but I think it still uses the other inputs of throttle position sensor, RPM, MAF to determine the load.
The later phase 11 autos have another speed sensor on the turbine shaft to determine the difference in speed between the impeller and the turbine that gives a direct read of load.
One Arm Bloke.
Tell it like it is!
Old 08-08-2012, 07:39 PM
Load is determined using the mass airflow rather than manifold absolute pressure sensors like newer ssubies do
Old 08-08-2012, 08:14 PM
Just saying : how on earth back in the day ( pre 1970 ) did we ever operate an automobile motor by just the use of a heat sensitive spring operating a small plate in the throat of the carb. ( automatic choke ) boy we have come a long way baby
Old 08-09-2012, 02:07 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Engine Load is usually measured as grams of air per revolution (g/rev). Some manufacturers do per cylinder instead.
The most basic equation is divide Mass Airflow (grams per second) by Engine Speed (revolutions per second ie. RPM divided by 60).
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 08-11-2012, 08:53 PM
Isnīt it easier to have the readings of an intake manifold pressure to know the engine load and adjust it with the readings from the RPM, MAF and TPS?
what does longassname think about it? (I send you a PM some days ago)
How does the new 1av1 calculate the engine load so it can tune the timing advance? would you recomend the use of a vaccum transmitter/sensor working together wit a new chip program?
Old 08-11-2012, 11:31 PM
kwren's Avatar
kwren kwren is offline
Actually it was a bit more involved than that
Keith
Old 08-12-2012, 03:58 AM
bazza bazza is offline
I've got a MY11 Forester S which runs the same engine / turbo as the MY11 Impreza... running MAF still. The only MAP based Subaru's I know of from factory are some of the MY02 Outbacks (H4 and H6).
MAP sensor is only used for boost cut and barametric compensations. However sometimes you can flash the rom to a Group N version which runs on MAP - romraider for more.
Originally Posted by b3lha View Post
The ECU needs to know the quantity of air it is getting, so it can work out the quantity of fuel to mix with it.
A MAF sensor measures it directly.
With a MAP based system you need to measure pressure and temperature and then calculate the quantity based on those readings. When you step on the gas, Mass Airflow changes almost instantly but Manifold Pressure lags behind. So you have to do TPS delta compensations to guess how the airflow is changing while you wait for the pressure to catch up.
MAF systems are faster to respond and more accurate. So they run smoother, especially at low rpm where precision is important. They suffer from less hesitation and provide better drivability. That's why most modern ECUs use MAF.
MAP tuning becomes a lot more useful when you increase the horsepower beyond what the manufacturer designed for. When your airflow exceeds what the MAF can measure, you either have to fit a bigger MAF (with reduced precision), or go to a MAP based system.
Some aftermarket systems like EcuTek RaceROM and Cobb Accessport can use MAF at low rpm and switch to MAP when the MAF gets maxed out. But obviously neither of those is available for the SVX.
Well said.
Old 08-12-2012, 06:35 PM
my goal, as always, is try to understand the control a little more. Our SVX have only a MAF, not a MAP.
The ignition timing on the original ECU fails in properlly advance the ignition, so we can feel the advance increase as we rise the RPM's in a 0 to 100 aceleration. It is too delayed. New softwares have inproved the preformance by advancing the ignition map, but what are the signal it takes and what is the weight of each of those to change the ignition map. I've read that the new 1av1 does not need to learn (the ignition timing advance) because it change the map everytime you drive the car but again, what factors makes the map be changed and in what proportion?
I'm planning to build my own HHO generator and install it on my SVX using GLP injectors @ 8-15psi. I'm working on the desing of all the components and in the software I'll use on the new micro PLC. This is going to be a seccondary ECU to control the HHO system. I'm willing to include a load injection increase feature (like the gasoline jet on the carburators). If I succes, I'll share this on this net.
Đ 2001-2015 SVX World Network
