Old 10-27-2012, 08:09 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Extensive work done to my car
My 97 Ebony has been at OT's since 9/14/12 getting tons of work done to put it in the condition it should be. Here is a rundown of whats been done so far.
MAINTENANCE REQUESTED:
Replace head gaskets (customer parts)
Replace timing belt and idler pulleys (customer parts)
Replace water pump (customer part)
Thermostat cover modification
Replace thermostat (customer part)
Oil pump modification
Reseal engine with new gaskets
Replace Vacuum/ PS/ ATF/ Coolant hoses
Replace PCV valve
Replace I.R.I.S. valve
Replace spark plugs
Replace P/S idler pulley
Replace A/C idler pulley
Replace knock sensor #2
Replace 6 coil packs (customer parts)
Replace emissions valve
Replace front and rear brake calipers (customer parts)
Replace front and rear brake rotors (customer parts)
Replace front and rear brake pads (customer parts)
Install stainless steel brake lines (customer parts)
Flushed, refilled and bled brake system Valvoline DOT 3/ 4
15 minute suspension mod
20 minute suspension mod
Oil change and oil filter
Replace front and rear swaybar bushings (customer parts)
Replace steering wheel (customer parts)
Replace transmission shift handle (customer part)
Replace main cat Magnaflow 94007 (customer part)
Replace exhaust resonator
Replace 3 oxygen sensors (customer parts)
Install O2 bung for 3rd. sensor
Check crank sensors/ Cam angle sensors for proper operation
Install HID fog lights (customer parts)
Replace broken transmission pan bolt
Repair dented transmission pan
1995 POLO LSI 76K MILES SOLD
Old 10-27-2012, 12:59 PM
Rod.'s Avatar
Rod. Rod. is offline
Re: Extensive work done to my car
That's quite the work order! Good on ya, and best of luck to getting her back on the road!
Rod.
'97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD
'92 Ebony LS-L #6851, USDM (sold)
'08 Forester (wife's)
'06 STi (traded for the Forester)
'94 Legacy wagon (sold)
Old 10-27-2012, 03:04 PM
When were you going down to pick it up? (Assuming it is ready.)
Old 10-27-2012, 03:17 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Mmmmm lots of upgrades and repairs. Hope you enjoy!
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-27-2012, 08:22 PM
theflystyle's Avatar
All I see there is $$$...
1994 SVX LSi
2008 Legacy 3.0R
Old 10-27-2012, 08:25 PM
BUT you saw it today and commented on how nice it looked.
Old 10-27-2012, 08:42 PM
Huskymaniac's Avatar
Uses the ignore feature
Did you get my email?
Tony
SVX92-97's Avatar
will be picking it up within the next few weeks
Old 10-27-2012, 08:59 PM
Just now.
I've been under some cars.
Old 10-28-2012, 08:09 AM
your right, i really like that color. she looked totally worth it.
1994 SVX LSi
2008 Legacy 3.0R
Old 10-28-2012, 10:11 AM
Great job! These cars are worth every penny you spend on them.
Old 10-28-2012, 11:05 AM
IF you keep them and enjoy them.
