Front Stabilizer Issue
The upper part where the stabilizer is bolted broke off. The stabilizer is now just dangling. What was the stabilizer bolted onto that I need to replace? Thanks for your help.
Re: Front Stabilizer Issue
The flange broke off the strut? Or the top ball joint of the endlink (that's what that gold-ish coloured part is called) pulled out? If the flange broke off, you're kind of SOL and will need a new front shock to fix it. If it's only the link that separated then you just need to replace that, although they aren't cheap (~$75).
You might be right. I took it to the mechanic. He said I need to have the whole axle replaced. He quoted me at $450. Does that sound like a legitemate price?
Thanks |
No. This connector runs from your stabilizer bar, under the car, to the other side. On both struts, they connect to those little "ear" on the strut body. Your CV axles are completely different. And if they DO need to be relaced, you can get remanned ones for under $80 per axle and probably put em in yourself, or have a friend put em in for much cheaper. I don't see anything on that stabilizer linkage broken in that picture... is this an old picture prior to breaking?
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
I'm going to guess that the tab on the strut body broke off (been there, done that, twice). You can weld them back on, just be careful with the amount of heat (use MIG, not a torch).
-Bill
Yeah I think you're right Bill. I'm probably going to have it welded.
If I choose to replace it, what part would I actually need to replace and how much do you think it would cost? I have attached the actual pics. Thanks again |
