Spark Plug Wires
Can the spark plug wires be a big problem?
If so whats the best and most convenient solution? |
Re: Spark Plug Wires
Our cars don't have spark plug wires. We have individual direct ignition coils. Problems? They will fail eventually. When they do that cylinder won't run anymore. Solution? Buy a new coil. Not exactly a regular failure item, which is good because they cost $75+ each (there are 6 of them).
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 02-20-2010 at 03:27 PM. |
Ok thanks, i must have got the wrong Info.
What happens when the coils start failing? And does the car vibrate or choke at low speeds? |
When the EG33 is missing, you'll know it. At idle you'll hear an irregular exhaust note (thumping sounds, I could hear mine missing at idle from across the parking lot), the whole car will be shaking like a cammed out big block, it will have very little power.... I've never driven the car at speed with a bad coil, I limped it to the shop across the road and fixed it.
I see, thanks, driver i talked to had issues with the coils earlier, and replaced 2 of 6, I was wondering if i should at least repair 2 more, before buying the car. To save some trouble on the long run, it runs fine now. What do you think?
I wouldn't worry too much about them. What's the mileage on the car? One thing you could do is buy one of the front coils to keep as a spare. The front two have the longest wires, which will allow them to be used on any cylinder. They don't really give much for warning signs in my experience.
