#151
Re: ECUtune Stage II reviews
the STI yellow tops are 565ccs i think... good size injector. When you say dual SVX mafs... how would that work on a single turbo... split intake or one in the inlet and one in the charge piping... how about both in the charge piping? I was also thinking... maybe run a z32 maf in blow thru... would that work better?
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill. 1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback |
#152
The dual air flow meters are run in parallel with a dual intake. They could be in front of the turbo or they could be blow through after an intercooler.
Wanted to share an update on my 2v7 experience.
I have now installed the 60-1 turbocharger, which is much larger than the small hybrid previously installed on the car. I am running 2v7Flex fuel version on gasoline map currently. In addition, I have moved to a blow-through which provides improved throttle response when compared to when I placed the MAF in the fenderwell. This may have nothing to do with blow-through and everything to do with the distance the MAF was from the combustion chamber previously. In anticiaption of that, I have placed the MAF in close to stock distance. Additionally, it its upstream from the bypass valve and It no longer hunts for idle coming off of boost. The car drives remarkably well. it accelerates smoothly and does not appear to have holes. Due to the size of my intercooler, I get some heat soak at the top of third. For safety measures, I have installed a 6:1 RRFPR for added fuel. Thanks again Mike and look for some dyno numbers in the near future.
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. Last edited by Phast SVX; 07-02-2009 at 11:20 AM. |
#154
what does that turbo flow? What PSI are you running now, Phil?
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#155
approximately 9psi at the manifold, and It spools by around 4500rpm.
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#156
Here is a guesstimate plot at 6500-rpm 1.65 Pressure ratio at .75 Bar, 11.5:1 AFR, 90% VE estimate. Even if my adiabatic efficiency comes in lower I am in the 70% sweet spot for CE.
#157
Um, I passed emissions today. Whoo hoo!
#158
So what would I see as a difference between 2v7 and 2v7 aggressive?
Power? MPG? I have wrx 5 speed, msd, stebro, pully, 1v5 etc.
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
#159
When it's actually released I will release it as Stage2Av1. It's stage 2 software with the same fuel and timing maps as the stage 1 aggressive software. The main feature of the "aggressive" software is that it no longer depends on/uses the knock sensors to seek the edge of knock and add in a reasonable/optimal amount of ignition advance. I put all the ignition advance straight in the primary ignition advance table so you run full/optimal advance by default. The knock sensors are only used to retard the timing if knock is sensed. There is also a new fuel map used for the default software. With the new fuel map you get improved fuel economy along with improved performance. The 2nd tune on the memory adaptor (the one that runs if you send +12v to the memory adaptor) runs the old fuel map with the new timing maps and offers even better performance but no improvements in fuel economy.
#160
So i assume that is what you would recommend for my build? When are you planning on releasing the new software?
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
#161
After some people run it for a while and it is proven. I expect the aggressive version of stage 2 will give the same improvements the aggressive version of stage 1 does over the original but it's unproven as of yet.
I'd release the stage1av1 already but I'm stalling in order to do one big website revision and change to the product line up. |
#162
#163
Cannot wait to get this in to the car this weekend. Should have some video of the butt-o meter in action.
#165
Upgrayyedd! will take it for a cruise tomorrow.
