Old 02-08-2006, 01:33 PM
SubyLuver SubyLuver is offline
Loyal Subie-ist
Send a message via MSN to SubyLuver
Brakes & lines
I noticed through searching that this topic has been covered, but i couldnt find a how to on the brake lines. I need some help with my new SS brake lines... I am sure I can figure out how to take them off and put new ones on, but I am sure that introduces alot of air into the system(which is a no-no)... How do I do this effectively? I have 2 cans of ATE Super Blue so I am not worried about losing all my fluid in my lines since the old $hi! is going to be gone anyways...
Thanks guys
Subyluver
'92 Subaru SVX Ebony 216k miles
(Magnaflow Custom Cat-Back, ES Stablizer Bushings, Permacool Relocator, 2.5RS FPR, SS Brake Lines, EBC Green Pads, Raceconcepts D/S Rotors, Pirelli P-Zero Nero M&S)
(To-do list Koni Struts & Springs lacking funds)
Old 02-08-2006, 01:45 PM
Earthworm's Avatar
Meow!
I have a set of SS lines but haven't installed them yet. I'm waiting for it to warm up. If no one has one by then I'll writeup a how-to.
Old 02-08-2006, 02:32 PM
If you are not sure how to bleed the brakes, you should have a mechanic install them for you.
It will only take him about an hour of shop time, and he has probably done it hundreds of times.
WOO HOO 2000 posts!
Old 02-08-2006, 03:38 PM
Loyal Subie-ist
WOO HOO 2000 posts!
I am pretty sure that all you do to bleed the brakes is open up the bleeders and step on the brakes until you see your new fluid running through, blue in my case. I know you have to maintain fluid in the resevoir so no air gets in... That was not reallly the question. I was asking if there was any way I am supposed to do my brake lines besides basically flushing all the fluid out of the system? (cork the holes or something?) And I was also asking if there was a howto on it someplace...
Thanks
Subyluver
Old 02-08-2006, 03:46 PM
Earthworm's Avatar
Meow!
There's more to it than that.
Old 02-08-2006, 03:59 PM
There is also a sequence that you need do to bleed the brakes. I will try to find a How-To.
Old 02-08-2006, 04:00 PM
immortal_suby's Avatar
Thread Killah
Well, not much more.
You either need a speedbleeder or 2 people.
The 2 people method is this
1st guy has a wrench in hand on the bleeder with bleeder closed
2nd guy pumps brakes until hard then keeps foot on pedal
1st guy open bleeder and brake fluid sprays out (good idea to have a 1/8 inch clear tube over bleeder leading to a clear container)
2nd guy hollers when brake pedal gets close to floor
1st guy closes bleeder when hears hollering
1st guy hollers ready when bleeder is closed
2nd guy pumps brakes again until hard then keeps foot on pedal
and - repeat until clear brake fluid comes out on all corners. Make sure to keep fluid in reservior - if you drain it you introduce even more air into the system.
Also - always start with the brake that is furthest away from the reservoir and move in.
Never done the speedbleeder method maybe someone else will chime in on that.
Locker Link
2015 BRZ Limited 6MT
