Old 07-23-2020, 12:22 AM
irox irox is online now
Nice SVX! I feel the gold wheels on Teal give it slight Lotus (Green/Yellow) feel.
Noting that the (original) Lotus Esprit and SVX share the same designer.
Cheers!
Ian.
Old 07-27-2020, 01:31 PM
RedLionSVX's Avatar
RedLionSVX RedLionSVX is offline
So you bought the SVX “by accident”?
Cmon! Let’s hear the backstory ! 🙂😀 That is a beautiful car BTW.
Old 07-28-2020, 02:00 PM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
I accidentally looked to see if an SVX was for sale, and there was, so I bought it
Old 07-30-2020, 02:12 PM
wdb wdb is offline
dances with roads
I did the same thing, a few years back!
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 07-30-2020, 03:57 PM
Put my Spec.B up for sale
We bought a truck and don't have room for all the cars. My new DD is a 2010 Pontiac G5
Old 08-01-2020, 10:06 AM
immortal_suby's Avatar
Thread Killah
Put a new battery in and discovered the brake lines are leaking somewhere in front of the right rear tire.
Locker Link
2015 BRZ Limited 6MT
Old 08-01-2020, 08:16 PM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
H6 Fanatic
Originally Posted by immortal_suby View Post
...discovered the brake lines are leaking somewhere in front of the right rear tire.
That's the primary reason I parked mine ...damn like almost 2 years ago. Whilst doing maintenance on my Impreza coupe recently, the rear brake lines disintegrated in the very same spot.
It's right where the lines that run the length of the chassis inside transition to the exterior, as you said, right before the rear wheel. Kind of a pain in the ass spot, as it's not actually the shorter rear lines but the long mid lines. I got a brake flaring kit and started practicing, it's not too difficult and will probly save me a fortune to be able to patch my own lines.
Edit: damn I gotta check my 97 LGT...
1992 SVX LS-L : King of the Stable
LGT 5MT, ABS Delete, Short Ram Intake, Custom Exhaust, Drilled/Slotted Rotors
1993 Legacy sedan : winter beater, supposedly.
1994 Legacy wagon : future drift car?
1995 Impreza coupe : EZ30++, daily racecar.
1997 Legacy GT : date night rocket?
2003 WRX : future winter beater
Old 08-05-2020, 03:51 PM
Use copper-nickel for your new lines. Much easier to bend and flare than steel.
Old 08-05-2020, 04:39 PM
SoCoNoHa's Avatar
H6 Fanatic
Thanks for the heads up!
Old 08-15-2020, 07:12 AM
Thread Killah
Not finding these part numbers for it, from a 2014 thread....
Brake Line Repair for SVX rear;
Two brake lines PAJ-351 (R+L)-----------------$18.00
Brake line PAJ-320----------------------------------$6.00
Brake line PAJ-312----------------------------------$6.00
Two brass unions BLU9C--------------------------$9.00
One can truck bed liner to protect brake lines--$11.00
Special clips to hold lines to body-----------------$4.00
Valvoline Synthetic fluid---------------------------$7.00
Parts--------------------------------------------------$61.00
Rear fitting goes to the RR wheel,
Front fitting goes to the LR wheel.
Locker Link
Old 08-17-2020, 01:45 PM
ZoraSVX ZoraSVX is offline
That's sad... Spec B is at the top of my list of favorite sport sedans.
- Lenny
Current car: 2006 Saab 9-2x Aero, Midnight Black Mica, 180k miles, 5MT, mostly stock
Past car: 1995 Subaru Impreza wagon, EJ20G w/5MT, Koni Yellow inserts/STi wagon (GF) springs, swaybars, and other suspension goodies, STi seats
Future car: SVX, of course!
Old 08-17-2020, 02:01 PM
jes's Avatar
jes jes is offline
gave it to my daughters... too many cars in the driveway...
Old 08-29-2020, 12:35 PM
SacSVX SacSVX is offline
Some of you might have seen my facebook svx nation post. But my car failed to start after being driven just a few weeks prior. I was in the middle of moving to a new place and wanted to set everything up at my new house before bringing my SVX over. Well. I had my previous place all cleaned and up was about to drive the SVX over and lol it didnt start.
Long story short, it turned out to be a faulty connector above the fuel pump. unplugged connector, cleaned, plugged back in, and runs.
SOooo yea, that's what I've done lately
Old 11-21-2020, 07:10 AM
SVX_MY_BABY's Avatar
Ready for winter. Another application of Rust Check and winter tires are mounted.
Peter
Old 11-22-2020, 07:20 AM
jkp jkp is offline
Changed the rear differential oil , in hopes the binding will stop. Regardless of whether this cures the problem, it sure needed it . The drain plug magnet was fully encrusted, the oil very dark and loaded with metallic sparkles. I can`t believe how much the previous owner neglected this car. Now I have to assume the front diff is just as bad, if not worse, but harder to get to, without a lift.
