Old 12-28-2013, 10:41 AM
will do later today.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 12-29-2013, 02:21 AM
Tapani Tapani is offline
Replaced the pollen filter on the Outback..... there's none on the SVX, right?
/T
Old 12-29-2013, 09:19 AM
picture of the camera. pretty small and hard to see in crappy picture. the mount is behind the plate and the camera hangs over.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 12-29-2013, 10:09 AM
MCMXCII SVX's Avatar
MCMXCII SVX MCMXCII SVX is offline
Quite interesting. Where did you mount the display?
Old 12-29-2013, 12:35 PM
theflystyle's Avatar
Do you have a link to which camera you ended up getting? Is it wireless?
1994 SVX LSi
2008 Legacy 3.0R
Old 12-29-2013, 01:35 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Replaced the aircon controller with one that Shane Hobson had as a spare - now just got to figure why the one in my car kept going to min. temperature all the time....will do a write up about what I find.
Old 12-29-2013, 02:11 PM
Gamesy's Avatar
Gamesy Gamesy is offline
install new clutch in OBS
Old 12-29-2013, 03:48 PM
92 SVX 92 SVX is offline
Is your a RHD unit that reads in C?
The Capacitors on the board (i think 3 of them) tended to fail, there is a few write ups on it. I know a guy here florida that modified a JDM unit to fit in the USDM hvac housing he had that problem and he unsoldered the caps and replaced them fixed the problem.
Old 12-29-2013, 03:52 PM
SURTEESS's Avatar
Yes it is RHD & reads in C - got the Japanese link (I posted here earlier) - so just got to desolder them & get new ones from my work place.
Old 12-29-2013, 04:08 PM
This tells of his conversion to the jdm unit, inside the usdm housing, and his problems with the temp going down, and his eventual fix.
http://svxworldforums.com/forum15/3114-1.html
The short version is he cleaned the board it seemed to have corroded, and replaced 3 caps, I think he tells which ones.
Old 12-29-2013, 05:42 PM
Subachouli Subachouli is offline
Subaru Parts Guy
Today the side skirts, trunk, and grille went back on. Then I took the car for a quick zip around the block because I missed the exhaust note.
1994 SVX- 5MT, Deltaspeed, Stebro,Work VSXX
1994 Legacy GT
2001 Forester
2002 Impreza WRX
2005 Impreza WRX STI
Need parts?
Old 12-29-2013, 07:21 PM
Absolutely beautiful!
Old 12-29-2013, 08:28 PM
Gamesy's Avatar
Originally Posted by gwynethh View Post
Mostly finished the sub woofer box for the trunk. We got a good price on a cheap 12" sub and tried to follow the recommended volume for best response. Final outside dimensions about 33"X7"X14". Used 3/4" MDF and covered it with the same vinyl we used on interior pieces. Not cutting edge but should do the job.
This was the second attempt as the first had vinyl problems at the sharp corners. Solved by router-ing a 1/2" radius on the long edges.
should've done an indent like i did here
http://i566.photobucket.com/albums/s...o/IMG_1861.jpg
Old 12-30-2013, 05:55 AM
Subaru Parts Guy
Thank you for the kind words
(Means a lot from someone who has probably seen his share of SVXs over the years)
1994 Legacy GT
2001 Forester
2002 Impreza WRX
Need parts?
Old 12-30-2013, 08:08 AM
gwynethh's Avatar
gwynethh gwynethh is offline
very nicely done.
