Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
  #31
Old 08-29-2010, 10:12 PM
Nevin's Avatar
Nevin Nevin is offline
Re: To Build A Track Car...
Originally Posted by SomethingElse View Post
typically I see a/c systems run around 150 psi on the high side under load. I don't see why you couldn't run oil through it...its made for gas though and your trying to force a liquid through it....may run in to some complications.
I think the passageways of the a/c condensor would be too small to carry oil through at a high enough volume to be useful. It seems like it would create a very high pressure (which isn't a horrible thing) but at that high pressure the oil would pass through too quickly to be properly cooled. That's just my guess though.
Normally oil coolers tend to run like -8 or '10AN fittings. The fittings for the a/c would be much smaller. But I could easily be wrong, not having looked carefully at the SVX condensor.
Though why try to re-invent the wheel when an effective alternative already exists?
Jesus is the remedy
2015 Expedition EL Ecoboost
Ebony Pearl '95 Subaru SVX LSi
Home of the Bontrager Works 22mm rear sway bar!!
Old 08-30-2010, 04:52 PM
rallyingrob's Avatar
rallyingrob rallyingrob is offline
oh for sure....no need to risk engine trouble when alternatives are so easy/cheap to install...
just thought it might be a clever way to "reduce reuse recycle"
lol
i'm too svxy for my car
rob
92 ebony 4.44's rock !!
Old 08-30-2010, 05:15 PM
Nevin's Avatar
lol
Haha, well no harm done. And like I said, it's a good thought, but I just don't think it'd work well enough.
Jesus is the remedy
Old 09-13-2010, 07:49 PM
juice's Avatar
juice juice is offline
Juice
Talking Re: To Build A Track Car...
not sure if this was mentioned but i just saw an 11 lb. carbon hood I thought was pretty sweet.
Old 09-13-2010, 08:30 PM
13# fiberglass hood here.
http://www.subaru-svx.net/photos/use...svxfiles|35429
Old 02-02-2011, 12:58 AM
Banned
anything done with this car?? pics???
Old 02-02-2011, 11:06 AM
ridered777's Avatar
ridered777 ridered777 is offline
Finally HAS a 3rd pedal!!
Send a message via AIM to ridered777 Send a message via MSN to ridered777 Send a message via Yahoo to ridered777
its more of an informative thread at this point. The car I was going to use I decided to save its life...its at the body shop now getting an all black paint job and I am re sealing the enginia and mating it to an 02 wrx trans.
More than likely ill find another car in worse shape than this one was...then make another attempt..I think there are a lot of useful tips in this thread and will be applying most of them to my gold car.
-Craig
94 LSi 5spd Barcelona Red, 14Xk miles.
Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior.
(up next) Full cage, fuel cell, 327 swap
Old 02-03-2011, 12:45 AM
Banned
shhh Craig... I was lazy ok, I skimmed... shhh... someone needs to make a roll cage before I try it! besides the desert racer I need something more along the lines of the pace car just still able to pass scca regs
Old 02-04-2011, 03:04 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
You won't see anything like the pace car roll bar passing scca regs. Hocrest posted the link to the place that made ours. They have the dimensions on file. It will fit in a stock interiored car as they used Dave's interior to do the measurements.
Old 03-11-2011, 07:30 PM
Heat Seeker WS6's Avatar
Heat Seeker WS6 Heat Seeker WS6 is offline
So who's tracking thiers?
Running up miles at Road America since 97
ok......... so it's not an SVX....yet
Learning the ways of the SVX... One bolt at a time
