front control arm and sway bar bushings
i did my front struts yesterday and went to get an alignment dont but unfortunately they couldn't do it because they said the control arm bushings were shot on the front. so now instead of having money for a windshield from nate....i now need these bushings or the whole control arms...anyone have any for cheap or know where i can get some these are all i want no more.
thanks, Jared *sigh*
Jared 1992 dark teal SVX LS |
Re: front control arm and sway bar bushings
Poly Control arm bushings can be picked up relatively cheap new I believe. (aftermarket of course)
I think I have some control arms in good shape, but have no idea if they made it out here to PA yet, or if they're in WI or Illinois. Having parts scattered can suck at times. |
Do you know where I can get them? I saw a bunch of posts about them but couldn't find out where they got them
http://www.strongflex.vot.pl/index.p...emart&Itemid=1
What you want are called: Subaru SVX, Front Wishbone Front Bush Subaru SVX, Front Wishbone Rear Bush 2 of each and I recommend the yellow ones. Changing them is a pain in the ass... A shop press should be able to handle getting the old ones out. New ones slide right in. Grease the crap out of them (they come with grease).
As for coming from Poland... Just be happy you can get them at all. The only alternative is new OEM control arms, which ain't cheap and is a sad reason to replace control arms.
