Old 08-22-2009, 03:20 PM
Paulrio74's Avatar
Paulrio74 Paulrio74 is offline
Won't start, second opinion please
I think it is the starter, but would like a second opinion. There is no clicking that I can hear. I parked it, and when I came out, the dash idiot lights come on, but the starter doesn't engage. From the searching I did, I think it would be the starter. Could it be the fusible link, or something along those lines, maybe the relay? There is sufficient voltage at the battery and starter, but can't test the alternator as the engine doesn't turn over. The alternator is a 2 year old Bosch put on by the dealer for the previous owner.
Old 08-22-2009, 04:32 PM
Re: Won't start, second opinion please
First turn off all things electrical, lights, radio, AC, interior loghts, etc.
Put on the parking brake, and shift the SVX into neutral.
Now keep trying to start it by turning the key to start.
Try it at least twenty times, preferably with a jump pack hooked up.
Then report back.
BTW you know that that are two
+wires that go to the starter, not counting the ground.
Old 08-22-2009, 05:25 PM
oab_au oab_au is offline
Then report back.
And if that does not work, try holding the key in the start position, and moving the gear lever between Park and Neutral. See if it starts.
One Arm Bloke.
Tell it like it is!
Old 08-22-2009, 07:08 PM
And if THAT does not work, did you recently disconnect the battery?
Old 08-22-2009, 07:15 PM
michael's Avatar
michael michael is offline
What Potholes ???
If this is the case, I'd say your battery terminal is loose or dirty. This happened to me the other day.
Wanted: Steering Wheel
Old 08-22-2009, 07:18 PM
OR, he needs to reset his (anti-theft) alarm system.
Old 08-22-2009, 07:33 PM
trophy956 trophy956 is offline
hi it seems llike it worked when you parked it ,starters rarely die with out signs ,there is no oem starter relay ,if you have a oem security system there can be a starter inturuped relay in the car ,but personel opinion is your car is suffering from voltage drop, if the battery is good ,buy or make a remote starter button ,its just a tool to help diag cars ,but there are many people here who talk of putting a relay in line ,i did this too but i used a oem 30amp relay from a kit subaru sells for mid 90s to install power outlets
it comes fused and works well ,good luck
Old 08-22-2009, 08:16 PM
subiemech85 subiemech85 is offline
HOTWIRE it!
nobody mentioned it before
"Some work occaisionally is fine, but I bought the car for the road, not for the garage. " BoxerFanatic
click here for fuelly mpg info
Old 08-22-2009, 08:47 PM
Trevor's Avatar
Trevor Trevor is offline
Turn on the lights, shine them on something so you can see them, or have someone else observe the results. Turn the key to the start position. If the lights do not dim slightly, the starter is not drawing current. In this event several obvious items are suspect.
Trevor, New Zealand.
Old 08-22-2009, 09:22 PM
michael's Avatar
What Potholes ???
If it's daytime you can use the dome light.
Old 09-08-2009, 01:19 PM
Paulrio74's Avatar
Finally got it fixed. Turned out to be more than one cable that was corroded to the point of no copper left. Had to replace a them, all is well again. Thought I'd add that in case someone searches later.
