Re: Brembos
Here is what I currently have for a rear brake set up. Brackets will be easy, the hard part will be finding something that can use the whole rotor space while having enough room to make a bracket. It is an STI rotor paired with a z32 rear 2 pot calipers.
Front needs work. STI rotor and Cadillac Brembo's yrilds no room for a bracket. Will be buying a 355mm NISMO rotor that should be a perfect fit.
Check out a newer Facebook group for all things SVX, SVXNation Or follow us on Instagram @svxnation http://SVXNATION.COM |
Re: Brembos
Making anymore headway on this..will 17" rims allow enough room for your proposed set up?
Cheers
1992 Dark Teal LSL, 4.44 swap, B&M trans cooler, AFPR, RX8 rims, 235/40-18 tires, SS brake lines, Hawk HPS pads, Strongflex poly ft/rr swaybar bushings, starter solenoid mod. |
Re: Brembos
We did a group buy of front caliper brackets on Facebook last year. Darin Entriken had them made IIRC.
Re: Brembos
I have tried several different photo sharing sites. None seem to work -.-
Check out a newer Facebook group for all things SVX, SVXNation Or follow us on Instagram @svxnation http://SVXNATION.COM Last edited by clarkrp1027; 01-26-2017 at 12:36 PM. |
Re: Brembos
What is the cost of the brackets based on,....... .?
