Old 04-30-2011, 05:57 PM
Geoff's Avatar
Geoff Geoff is offline
Send a message via ICQ to Geoff Send a message via Yahoo to Geoff
A/C Compressor sometimes does not turn on
Just had the system completely vacuumed and refilled - When the compressor turns on, it works great. But about 1/4 times, it just will not engage until about 15-20 minutes later. I can't figure it out. Does anyone have any ideas why the compressor would wait to turn on, if the pressure checks out fine?
Thanks,
Geoff
Old 04-30-2011, 07:57 PM
Re: A/C Compressor sometimes does not turn on
I'd try pulling codes from the climate control unit; it's ridiculously easy. See the attached (toward the end).
Old 05-01-2011, 11:59 AM
Geoff's Avatar
Looks like it's reading a Code 15 - Refrigerant temp sensor open
Is this something I can take care of, or should I take it to the Subie dealership?
Old 05-01-2011, 12:08 PM
http://serial.cc/pdfs/AC___HEATER____AUOTMATIC.pdf
See page 22 for the location of that sensor. Probably not the easiest thing to get to, but you could get lucky and it just be a loose plug or something.
Old 05-01-2011, 12:28 PM
Geoff's Avatar
So I have to remove the glove box, and it's somewhere down there? My guess is that the system would need to be evac'd beforehand?
Old 05-01-2011, 01:13 PM
I'm not exactly sure how to change that sensor out. I'd first get a replacement sensor and then evac the system, then take apart as much of the dash/glovebox area and swap it out. Test it before putting it back together.
Old 05-01-2011, 03:44 PM
kwren's Avatar
kwren kwren is offline
I wouldn't think it would be necessary to evac the system...
Keith
Old 05-01-2011, 03:55 PM
Geoff's Avatar
Keith
Keith - Have you done the sensor replacement before? I'm just trying to figure out its complexity. I haven't even seen the evaporator core yet.
Old 05-01-2011, 05:03 PM
Cam Cam is offline
I would first make sure that the system is properly charged. I have been told that when they are not properly pressurized it will cause compressor to act sketchy.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 05-01-2011, 05:04 PM
Geoff's Avatar
It is. When the compressor does run, it's perfectly charged - Just had a local shop take care of that.
It's just that the compressor won't run sometimes...and the HVAC is giving me code 15.
Old 05-01-2011, 05:42 PM
Keith
That's just what I would do because I don't know any better .
$5 says there's a loose plug that's preventing it from working.
