Tires, Tires, Tires
So what kinda of tires are you currently using on your SVX and what pressure do you run them at???
1992 Liquid Silver LS-L (Sold-5/16/13) 1997 Spruce Pearl Outback (Sold) 2006 B9 Tribeca |
Bridgestone Potenzas on stock rims, about 38 front/34 rear. (I think spec is 33/29.) They were on the car when I bought it 22,000+ miles ago, and they ride well and are holding up fine. Not crazy about traction in the wet, though, so I might ask around for recommendations when the time comes to buy more.
dcb |
Summer:
Falken Azenis ST-115 225/45-17 44 front, 40 rear. Winter: Hankook W404 Winter Radials (Studdable, but no studs) 205/55-16 on stock wheels. Could care less what the pressures are. When I check/refill I set them to 35 front 32 rear.
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock Last edited by SVXer95; 05-26-2005 at 03:26 PM. |
Hancook 245/45/16s on Di's, Nick's and Dave's, and Hancook 225/45/17s on my Claret.
Double A traction, fairly quiet, and OK wear. In the spring/summer/fall but ,,, snow traction is minimal on the 16s, and nonexistant on the 17s
BF Goodrich Traction T/A, 225X50X16, V-rated, 42 PSI in front, forget the rear, but it's whatever makes the loaded radius the same size (I think about 32).
Good ratings at Tire Rack and tread looks pretty good with about 10K miles on them, much quieter than the Fulda tires they replaced, no snow here, but unable to spin them in the rain. |
I can spin them, In the dry!!!
Dunlop D60/A2 JLB. I use the factory-recommended pressures on the door frame.
This is my second set. I've been thrilled with them, but Dunlop has, of course, discontinued the tire. I'll probably try something from Sumitomo next. I had Sumitomo HTR-200s on my Justy and they were fantastic tires. They even held up well after a year of autocrossing on them.
