Hydraulic Lifts.. ???
Is there a "cheap" source for hydraulic hood and trunk lift supports? They're about $60-70 from online OEM part houses.. . Yikes!
Hoping So.. . Tired of getting partially decapitated, when I forget the wood support stick! .. or getting scared from the severe trunk SLAM! Thanks, Jim
Re: Hydraulic Lifts.. ???
I know there is a write up on the hood I got a link to the trunk in my signature. Very similar process for the trunk I did will work for hood
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black 92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho | DDM HID's 55W shining nice and white. |
is there a trunk strut redo with info? ... or did it never work out?
Thanks, Jim
Hood, yes! Attached is a graphic for the bracket for the strut... the way to get a professional job. The nuts are self locking good quality and keep the other component centered like it should be.
Trunk, no... Mickey Mouse or Dealer only. Keith |
Parts list, installation writeup and photos. http://www.subaru-svx.net/forum/show...uts#post668295 .
SO... I just order kits from Lift Support Depot for the trunk job (eBay link is closed), but order the parts for the Hood job (other thread) separately.. or do they make "kits" also.. ??
Thanks, Jim
I mean.. . from SPD.. . ??
.. . I wanna do the best.. most recent mods.. for both hood and trunk gas charged struts. These How-To's tend to flow.. as someone perfects a good mod.. into a better one! So for the hood, I should order SPD struts (SPD GSNI- 2449-89) and ballstuds directly.. then purchase bolts + washers myself. AND, for the trunk, I order "kits" from Lift Support Depot (#49136) for $33.30 each? SOUND RIGHT? Thanks, Jim
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 05-04-2011 at 07:09 PM. |
Click HERE for the easiest way to do the hood strut replacement. .
Should I try to get parts for both at ONE supplier.. or is the best now.. to get the hood struts at SPD.. and the trunk struts at Lift Supports Depot.. ??
Thanks, Jim
