Will this fit? Universal Bolt Pattern: 5 x 100 + 5 x 115
Found some wheels. this is the bolt pattern listed. does this fit the SVX?
James
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! |
Re: Will this fit? Universal Bolt Pattern: 5 x 100 + 5 x 115
Are you sure it's 115? Or just 114.3 rounded off? Either way, sure, they'll fit.
They're just drilled for both. If they are, in fact, 115, then they will not fit.
-Bill
I believe they should, GM cars that use 5 x 115 pattern can use 5 x 114.3 with no problem.
With some grinding, I fitted 5x112 rims of the Mercs on mine.
Seven tenths of a millimeter is hardly a major difference. Some wheel studs compared to others may have more than .7mm difference in bolt circle diameter. Chances are, if it is dual-drilled, it is drilled for 5x100 (subaru, VW, Scion, and others use that), and 5x4.5inches (almost everyone else from japan and the US use that. Metric european cars tends to use 5x100, a bit of 5x110, 5x112, and 5x120mm. And I think most of that is to be enough different as to not cross wheels between european brand cars. BMW wheels on Mercedes, Mercedes wheels on Audis, Audi Wheels on Ferraris, and Ferrari wheels on BMWs... it would be chaos. American and Japanese manufacturers seem to like the lower costs of modularity, rather than worrying about wheel design cross-over. It is also cheaper for suppliers to offer a more standardized set of parts. Not only wheels, but brake discs or drums, and hub assemblies, all have to be set to that pattern.
"What you plan, and what actually happens ain't exactly ever been similar..." ------------ 1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it. 2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan. 1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun. |
