Swaybar bushings
Are any of these the right size for the fronts. The front set I bought from Dayle at motorsport warehouse are to short, they wont fit. I need the fronts bad, as my red 96 is squeaking worse than a mouse. Car sounds like its falling apart.
http://www.autopartswarehouse.com/pr...nsion_bushings
1995 POLO LSI 76K MILES SOLD |
Check out my locker.
http://http://www.subaru-svx.net/pho...svxfiles|24445 They will need to be noched, and ground/sanded out to 18mm.
bingo (fixed)....
http://www.subaru-svx.net/photos/use...svxfiles|24445 so which ones did you use Tom, the energy ones? or is that dayle's installed?
I like the Energy 9.5105G for the front.
thats what I was leaning toward... no one around here stocks them though
I'm gonna have to order them or get a hold of the guys at indyauto. while on subject... I also need to read this later: http://www.subaru-svx.net/forum/showthread.php?t=24206
So, are the energy bushings the best/cheapest option for swaybar bushings? I found some online for 13.08. Anyone find them cheaper?
What is the easiest way to grind out the hole? Thanks! I've developed a bad clunk on the drivers side, so i checked the swaybar bushing, and its completely missing
`92 pearlie 220k Tranny Cooler, shift kit, stage 1v4, d/s rotors, axxis pads, Perrin Pulley '00 GMC Sonoma ZR2. Last edited by Merz; 04-28-2008 at 01:45 PM. |
