Grill technical aspects
Does the 1997/Euro/JDM grill improve air flow to the radiator? Has anyone done a before and after on operating temperatures?
On a related topic, that foam between the radiator and frame is deteriorating on my car. I want to remove it but I think it actually helps cooling. I think it prevents hot air from the engine cabin from being sucked in and passing through the radiator. I'm thinking of gluing or screwing in a flap of silicone in its place.
Re: Grill technical aspects
The engine temperatures do not change even without the grille. The gasket is now gone, it had a good life. Let it go...
You can get stick-on foam at Home Depot that is almost a perfect match for the OEM foam gasket. I used the remaining bits to seal up my basement door!
Early to mid 1990's cars were very over engineered. The foam? Good idea but not necessary. Power steering cooler? Totally unnecessary.
The front openings of the car are large enough already, I change in maybe 20 square inches of grill space isn't going to effect cooling at all.
Name another car that has one. Seriously! Not even the STI does.
*cough* transaxle *cough*
