Old 05-16-2005, 07:51 PM
magickfingers
stiffer springs that don't lower?
Hi - I'm wondering if it's possible to get stiffer springs that don't lower the car? I would like the firmer cornering but i live in the boonies and drive lots of dirt roads. No way could i afford to give up any ground clearance. I realize the lower center of gravity helps handling but i would be leaving my exhaust behind real soon. Also, i just won an Ecutune kit on ebay and will be installing it as soon as it arrives. Also planning to buy a Small Car shift kit right away.
Old 05-16-2005, 08:15 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
maybe a sway bar upgrade?
http://se30.dyndns.org:8080/SVX/svx_sport_parts.html
Old 05-16-2005, 09:24 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
A Koni/ground control setup can be configured to not lower the ride height. Downside is that it is not cheap and the Koni's require modification of the struts. Do a search. You will find a lot of info.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-16-2005, 10:04 PM
Mychailo can have them made to order.
Old 05-16-2005, 11:43 PM
mbtoloczko's Avatar
sans SVX
Yep, I can make you a set. I've presently got one such set in the works for another customer.
Mychailo
Visit my locker
Old 05-17-2005, 12:59 AM
magickfingers
What are we talking for price and availability? Thanks. Marc
Old 05-17-2005, 09:15 AM
mbtoloczko's Avatar
sans SVX
$375 shipped. Takes about six weeks to get a set to your door. Here is the info:
http://se30.dyndns.org:8080/SVX/svx_sport_springs.html
If you've got any questions, feel free to give me a call. My number is on the webpage.
Mychailo
Visit my locker
Old 05-17-2005, 10:35 AM
Word to Yo Motha
Completely forgot that you did custom runs....
Mychailo's springs are great. I have them on my car (ones that lower the car slightly). Since he can do custom specs, this is probably your best bet.
Collin
1995 L AWD
Locker
