Old 07-18-2007, 09:08 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Electronic Counter Measures ON
Send a message via ICQ to Sov13t Send a message via AIM to Sov13t Send a message via MSN to Sov13t
Yet another Trivia Question...
Start the car today, all the sudden I hear this knocking... at about 1 second interval... sounds like metal on metal. Give it a little gas... knocking speeds up. I am like **** ******* ******* **** **** ***** ****** FOR CRYING OUT LOUD....
Turn off the engine... start looking underneath the car.... checking if it is the exhaust or something... nope... keep checking around... nothing... Start the car again... knocking is still there... this time i let it idle and go around it once again... seemed to be coming from the bottom of the engine/transmission.
After 15 minutes... I start the car, knocking is very quiet now... so I back out and drive... stop and listen... everything is gone. I am puzzled, confused, lost, and dirty from lying on the pavement...
Here comes probably my favorite line: "Ideas are welcome"
-Sov.
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 07-18-2007, 09:25 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Since your car consumes engine oil, are you sure have enough engine oil in there?
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 07-18-2007, 11:50 PM
I hope so.
Old 07-19-2007, 05:16 AM
Sov13t's Avatar
Damn, you think I am that dumb?
-Sov
Old 07-19-2007, 06:39 AM
JaySVX's Avatar
JaySVX JaySVX is offline
If it sounds like it's coming from the bottom of the engine, that would be my first indication as well. Check your fluid levels. Does it make the sound while driving? Does it vary with vehicle speed or just engine speed? Check your tranny fluid as well. Could it be a cracked flex plate?
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 07-19-2007, 07:38 AM
No flex plate.
He has a 6 speed.
Sov13t's Avatar
Started the car this morning, no sound.
Due to the fact that I do have an oil leak, I check my oil daily...
Will check later today (in the daylight) to see if the problem reoccurs.
Thanks
-Sov
Old 07-19-2007, 09:11 PM
SSSVX's Avatar
-Sov
Like you said: "Ideas are welcome." I don't mean to! First guess.
Is your car parked at flat ground? Sometimes if it's not, the dipstick won't give accurate reading. And, you have a leak, you never know if it leaks faster than before.
-SSSVX
Old 07-19-2007, 09:30 PM
Sov13t's Avatar
No worries
Its not making that noise anymore... or at least not as loud... here is what I believe occurred:
There was an echo effect created by the two vehicles that I was parked next to, so whatever the sound I heard was amplified.
Now, if I listen really closely i do hear a clicking noise... it doesnt sound like its mechanically incorrect or anything... now I believe this noise is normal for the engine... as I've heard it before... but I am not 100% sure. Anyways, I will be at OTs this Saturday just to take care of all the Asti before the meet HA HA...
-Sov.
Old 07-19-2007, 09:42 PM
SSSVX's Avatar
Were you drunk or were you awake?
Very good and real digital echo sound effects huh.
Don't know if I could go ... but if I do, that'll be great to see you. Don't drink too much Asti, more knocking noise later on.
-SSSVX
Old 07-19-2007, 10:00 PM
-Sov.
OH, NOOOOOOOS!!!!!
Old 07-19-2007, 10:05 PM
n02????
Anyway... sounds like mild rod knock bt cannot make any real judgement until I hear it in person... pretty common on 15yr old high mileage motors
Old 07-19-2007, 10:25 PM
Originally Posted by TomsSVX
n02????
Thats what I thought, but
Sov13t and I spoke earlier on the phone, and it sounds more like his new exhaust hitting the crossmember,
or something.
Way cheaper and easier than an engine.
