Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 11-25-2007, 08:36 PM
Just a few parts to install...
PWR rad, used from DarknessofDeath, Bridgestone Blizzak Revo1's from Tirerack.com, JDM clear corners from mbtoloczko, rear swaybar painted Raw FUrry Dog Red (ought to be good for +10-15HP), $15/15 min and $20/20 min mods from svxfiles, PCV valve, lightweight crank and alternator pulleys from Group A Performance, Energy front and rear swaybar bushings from Summit, new rear endlinks.
Just a bit of work to do.
Old 11-25-2007, 09:34 PM
Looks like you had better get to it then!
Old 11-25-2007, 11:06 PM
Have fun bro!
blk 92' LSL w/ average mods
Old 11-25-2007, 11:15 PM
Where will the skate board on the right go?
Old 11-25-2007, 11:56 PM
Hondasucks's Avatar
Subaru Technician
Dude, that's a snowboard. When was the last time you saw a skateboard with bindings?
1986 VW Jetta
Old 11-26-2007, 03:08 AM
didn't examine it much , thought the black thingies were the wheels... guess I should adjust the brightness on my screen
Old 11-26-2007, 05:44 PM
The snowboard goes in the trunk, on the way to the hill.
Old 11-26-2007, 06:07 PM
I had a dream last night I had a snowboard, then I woke up and realized there's no snow in Alaska.
Old 11-27-2007, 03:58 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Is the swaybar OEM, or is it an upsized bar? If it is an upgrade, what is the diameter, the source and the price. Thanks
Dan
Old 11-27-2007, 08:34 PM
Dan
lol, I wish. No, it's the OEM bar. I pulled it out to replace the bushings and thought I'd paint it while I had it out. Red is nicer then rust with a bit of black.
Old 11-27-2007, 11:28 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
how much did you pay for the new endlinks?
[SIGPIC][/SIGPIC]
STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit.
Old 11-28-2007, 07:56 PM
~$25 each from Subaruparts.com, I think. They're just OEM replacements, nothing special. My old ones looked like crap and had torn rubber boots, so I figured replacements were in order.
