Old 11-11-2010, 01:33 PM
Huskymaniac's Avatar
Uses the ignore feature
Clunking -> Rattling -> Squeaking
Ever since I picked up my 1996, I have had this clunking noise from the front end. I looked under the car and my mechanic did too and we saw nothing obviously wrong with the sway bar bushings, sway bar end links, tie rod end links or ball joints. The noises do not go away when braking so I don't think it is the calipers. The clunking was initially faint and only on bumpy roads and most noticeable at low speeds. The clunking has gotten worse with time. Keep in mind that the car is very clean as it is low mileage and from down south. I looked at the strut area under the hood and the nuts seemed tight and the rubber was in great condition. I seriously doubt the strut mounts are corroded. Also, I pushed down on the front quarter panels and didn't hear a noise and the car responded firmly without bouncing so I think the struts are OK. One question I have about the struts is with regards to the dust cover. Should it be pushed all the way up to the spring retainer with the bottom floating or should it be completely floating and sitting on top of the strut frame?
As the noise has gotten worse it is starting to sound more like a rattling sound with some squeaking thrown in for good measure. One interesting thing to note is that the squeaking comes in when the car is warmed up. And when the clunking was faint I would swear that I didn't hear it when the car was cold but only after it had warmed up. I now hear the clunking all the time but the squeaking definitely starts when warm. I even hear a squeak on the outside of the car when I shut the door. I can also make is squeak if I whack the top of one of the front tires. But again, only when warm. I was just outside spraying the sway bar bushings with silicone and I noticed that the squeaking went away when the hood was open. I backed out the rubber bumpers and sprayed silicone on the latch and it sounds like the squeak is gone. I am not sure where the squeaking was coming from but I am guessing it is where the latch grabs the loop on the hood. What is the best thing to lubricate this with?
The rattling really sounds like something bouncing inside an enclosure and banging against the inside wall versus two things banging into each other. That makes me think it has something to do with the steering rack.
Any and all suggestions on the source of the rattle are welcome and appreciated. I can live with the noise if I know what it is and I know it isn't a safety issue.
I did some research on this forum and on the web and found these as possible causes:
1. Sway bar bushings
2. Sway bar end links
3. Ball joints
4. Tie rod end links
5. Inner tie rods
6. Control arm bushing
7. Bad strut
8. Strut mount
9. Loose sway bar bolts (unclear as to whether this refers to bushing bracket bolts or endlink bolts)
10. Sway bar shifting to one side and contacting the control arm
11. Steering rack needs lash adjustment
12. Power steering relief valves
13. Steering u-joint
14. Loose bolts securing the front suspension subframe to the car
Tony
Old 11-11-2010, 02:31 PM
Cam Cam is offline
Re: Clunking -> Rattling -> Squeaking
it would not be a bad idea to replace the bushings for the suspension (end links, sway bar, etc.) Even if you don't replace them you should take them out and clean them, then reinstall them (I use lithium grease). New bushings will improve the ride and handling of your vehicle though. I only have replaced the rear sway bar bushings on my SVX (you could see daylight through them!) and it was extremely noticeable.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 11-15-2010, 01:57 AM
major7venth's Avatar
major7venth major7venth is offline
M7
If possible, get the car up (run up blocks work good) and have someone make the noise happen by bouncing car or whatever to make the noise and get all over and under the car till you can locate the area of the noise, go from there.
good luck
M7
Old 11-15-2010, 11:18 AM
wolfboy wolfboy is offline
I'm new here and don't know if this is the right place but, My SVX door hinges make a popping sound when you open and close them. Just wanted to know if that's a common problem with the hinges?
Old 11-15-2010, 11:52 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Lube them with spray white lithium grease, took care of mine.
Old 11-15-2010, 12:13 PM
I had an annoying clunk from the front end over bumps, mainly at lower speeds (parking lot type thing). I had thought it was my caliper slides being worn because riding the brakes seemed to help. However, after installing my coilovers the noise was gone completely. It was probably an internal part of the front strut's valving that was sticking. In any case, my car now rides like a luxo-sports car. Stiff and quiet.
Old 11-15-2010, 01:05 PM
Do they pop once or a few times as you open the door?
Tony
Old 11-15-2010, 05:25 PM
processengr's Avatar
I too, had unnerving rattle-clunking sounds in the front, especially when driving across washboard surfaces at low speed, on both of our 92s when 1st purchased (1st at 147k, 2nd one at 128k..) In both cases, replacing the front strut mounts/bearing corrected the noise. On my daughter's 92, those parts have been in use for 60k+ miles without further issue.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
