How do you get the wheel sensor out? PLEASE!!
The underside of my car is so badly corroded and rusted, EVERYTHING seems to never want to come out. I've managed to get the entire wheel sensor assembly out, with the exception of the action sensor itself..... the part that goes through the back of the hub.
..... it is literally welded inside there or something. I've already practically disassembled it from the inside out while prying at it.... and it won't budge. I've literally bent the retaining clip on the back side all out of whack trying to pry it out of there. I've literally stabbed three small flathead screwdrivers THROUGH the entire sensor assembly with a hammer.... it will not budge loose. I removed the large retaining nut to pull off the wheelstud retainer/basket assemble..... but that won't come off either. It spins, but won't slide off. WTF????? How do I get this thing out of here????
--Matt 1978 Subaru Brat, Gold+rust, project 2006 Subaru WRX, CGM, Cobb stg 3, VF39 2007 Subaru B9Tribeca 7-pass ltd, PSM 1994 Subaru SVX LSi, Bourdeaux Co-Founder / Site Admin: www.slcsubaru.com |
Re: How do you get the wheel sensor out? PLEASE!!
A socket with an OD slightly smaller than the ID of the hole. Or another blunt object. I have had them come out in about a million pieces... But as long as it is the one going in the trash it does not matter
Tom |
Jesus Mary Mother of God.
NEEEEEEEEEVVVVVVVVER have I spent this long on one single little insignificant little part as I did today. Never 5 friggin hours.
Good job dude!
You = 1 Sensor = 0
mine came out much the same way, due to age ,salt, dirt, etc it was recommended, by subaru tech, to put antiseize on outer shell upon putting new one in to prevent this from happening to be as hard in future.
William |
All I can say is hurray for penetrating oil. I sprayed mine several times over a few days before trying to remove it, and managed to get it out with only a little bending of the bracket.
