Old 04-23-2009, 11:51 PM
Black88GTA's Avatar
Black88GTA Black88GTA is offline
look like a leprechaun to me
Does the mast antenna ever go bad? Reception problems.
Not the mechanical parts (like the motor or mast, etc). I'm concerned with reception.
Some backstory...when I got my car, the power antenna was trashed, so it was replaced with a used part. The used unit still didn't work at first, because the power antenna lead had been cut behind the radio (lame / incomplete wiring job by the previous owner). So, I fixed this, and now the motor was running, but the mast wouldn't extend / retract all the way. After polishing the mast (huh huh ) and tweaking it section by section, I got it working perfectly (well, mechanically at least).
So now it's connected properly and extends / retracts fully when it is supposed to, but the reception is terrible. It pulls in plenty of stations, although none of them really well - even local stations are staticky and fuzz out at times. I am running off of the mast alone - the glass antenna is currently disconnected. I figured this wouldn't be too big a deal, since I've owned plenty of cars with only a mast antenna that get great reception, even from distant stations. The head unit (if it matters) is a Dual XDV8525.
So what gives? Is there something in the power antenna that can go bad and screw up reception? Or is it something to do with the fact that the glass antenna is now out of the loop? I am in the process of modifying a standard 1M ==> 2F Y-adapter that will allow me to plug both antennas into the jack on the back of the deck, but I don't think I should have to do this in order to get acceptable reception.
Anyone have similar issues that they fixed? Do I have to get a replacement power antenna unit, or is there something in there (a wire, etc) that I can fix if I remove it and crack it open? Or is this just the way it is?
Ebony/Gray '92 LS-L, @123k - bought 01/17/2010, parked for 10 years. Getting back on the road.
Old 04-24-2009, 08:23 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Does the mast antenna ever go bad? Reception problems.
I wouldnt use the Y adapter, that will just make things worse. It sounds like maybe the sections of the mast might not connect well, making it a smaller antenna so to speak. This is assuming that you have checked and double checked your hard connections at the deck, the extension connection by the transmission hump, and at the antenna itself. I pulled the guts out of my old power motor (broke inside) and just use the mast permanently extended, works great even out here in the cuts. Maybe you polished the mast one too many times (yuk yuk yuk)
Old 04-24-2009, 08:45 AM
BoxerFanatic's Avatar
I just bought one of these, from an ebay sale from the company listed here... (buy only, not an auction... but not listed at the moment.)
http://www.locustom.com/shark2_kit.htm
This link actually shows some installed pics at the bottom of the page...
http://www.locustom.com/antennas.htm
The antenna itself is made by Fuba, evidently an OEM distributor to many car manufacturers.
I am going to try to install it on my Miata this weekend, to replace a power antenna that got bent, and won't fully retract, and stands about the same height anyway. I figure the power would be better used for amplification, and the fixed antenna is less likely to get bent again.
Something like that might or might not fit an SVX... and the amplification might help the static issue.
But agreed, Y-connecting two antennas will probably not do beneficial things for the tuned length... Better to run one good antenna, if the stereo is not capable of diversity tuning, with two individual inputs.
Or, for the cheap, you could put a plastic body plug in the mast antenna hole, and just hook up the glass antenna instead, as the only antenna.
Old 04-24-2009, 10:49 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
I agree on not using a Y adapter — combining the two antennas in parallel will cause an impedance mis-match. You may get better reception, but only because the motorized antenna is so crappy. I think you'll find that you'd get even better reception with the window antenna alone.
It sounds like you're not getting good continuity out to even the lowest segment of the motor antenna. Unplug the coax antenna cable at both ends (side of transmission hump and base of antenna motor) and use an ohm meter to check the car's cable. While you're at it, go ahead and check from antenna jack at the base of the motor to the first segment.
The antenna installation instructions are in the How-To section, here:
http://www.subaru-svx.net/photos/files/How-To/28253.pdf
(whoever wrote that guide did an excellent job!)
The bottom-most portion of the mast is hidden until you disassemble it. Perhaps cleaning that will help.
Since you'll have everything disassembled anyway, you should also clean the inside of the tube that the coax attaches to. Only clean in one direction inside the tube. See step 12 of that guide!
Of course, the problem could be in your aftermarket radio. I'd try temporarily testing the radio with another antenna, and another car radio with the SVX's motor antenna.
David C.
1996 Laguna Blue Pearl SVX L AWD
See my home page for SVX radio install/removal instructions and wiring harnesses
Old 04-24-2009, 05:15 PM
Black88GTA's Avatar
Thanks for the help, all...maybe I'll scrap the Y-adapter idea, since it seems that isn't going to work as intended. I figured combining a (possibly incomplete) signal from both would patch the missing bits in and give the most "complete" signal to the deck. I don't really want to do a fixed rubber antenna, just don't like the look much myself...if I can't get the power one working right, I'll probably just unplug it and run with the glass one, even though I wasn't too impressed with that one either when I had it hooked up.
SVXdc, thanks for the install link...I'll check the cords / connections first, then start disassembling if that doesn't work. How would I check the cable running from the front of the car to the trunk using a hand-held ohmmeter without removing it? Long ass leads with alligator clips? Would I just be checking continuity, or resistance? Outer connector, or center pin (or both)? And if I'm checking resistance, what values should I expect to see if it is normal?
Sorry for all the questions...
Old 04-24-2009, 06:15 PM
Trevor's Avatar
Trevor Trevor is offline
I gather you have made a joint in the cable as a means of repair. Have you taken into account that there is an inner conductor insulated from an outer shielding sleeve, both requiring separate connection, as well as inner and outer insulation? Not a simple job but it can be done.
Trevor, New Zealand.
Old 04-24-2009, 07:39 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Id say forget about the glass antenna, when I had it hooked up alone my reception was only marginal. Its meant to be just a backup in case your car is in a bad signal position under a bridge or something like that where the main antenna is blocked. After I fixed the mast to my main and reconnected, my reception was much much better. If you cant get reception with the one you have, and dont want to pay bank for a replacement, id just go with a regular fixed mount.
Old 04-24-2009, 08:46 PM
Black88GTA's Avatar
Actually, no. No joints / cuts in the cable have been made yet. Currently, the deck is plugged in to the mast antenna only, and the glass is unhooked. I actually have a Y-adapter and a male antenna plug that I purchased. My plan was to cut one of the female sockets from the Y-adapter and install the male plug end in its place to connect with the glass antenna, and use the remaining female socket to plug in the mast.
That was my thoughts on the glass one too...really not that great, but it was lots better than the mast when I had it hooked up by itself. I'm going to do all I can to get the mast working properly though before scrapping it.
Old 04-25-2009, 12:06 AM
SVXdc's Avatar
Yes, extend your meter's leads with a long (good) wire. If you can, zero the meter with just the long wire. Then you'll be measuring the resistance of the coax. If you can't zero, subtract the value you get with just the long wire.
You're mainly looking for good continuity, but if the resistance is more than a few ohms, I'd start being concerned about the condition of the coax cable. The center conductor end-to-end is the most important, but no reason not to check the shield end-to-end while you're at it. Also check the resistance between the two (should be infinity).
I'd be interested to hear what you find.
Trevor, both ends of the coax cable for the SVX's motorized antenna have standard Motorola connectors, so it will be easy to clip or hold an alligator clip, wire, or test lead probe at each end.
David C.
Old 05-12-2009, 07:38 PM
Black88GTA's Avatar
So, a small update...I finally tackled this tonight. I messed with it a little bit last week, but didn't get much accomplished. It now pulls in stations I didn't even know existed
The first thing I did was check the wire. It tested out OK, but not trusting my measurements, I tried replacing the cable anyway. It was easy to just run a wire from the trunk to the front for testing purposes, so I hoped I'd get lucky and that's all it was. Unfortunately, this made it worse (if anything).
Tonight, I pulled the antenna assembly, took the whole thing apart, cleaned and oiled it, and put it back together using the guide found in the how-to documents here. The mast was dirty and sticky, so I cleaned all that crap off with some goo-gone spray I had here, until it was moving freely. It wasn't too bad before, but was really smooth after I cleaned it. I also cleaned the dirt off of the inner cable while I was at it, and all of the other parts as well.
For oil, I used some standard 10w-30 I had here. Probably not the most ideal thing for this, but it was all I had around, and it seemed to work ok. To get it up inside the mast, I stuck the bottom of it in the oil, and extended / retracted it quickly, so the oil "pumped" up to the top of the mast from the inside. It got a bit messy. After that, I removed the whole assembly from the oil, and extended / retracted it until no more excess oil came out of it.
While it was all apart, I also used a piece of stiff coat hanger to "pry" the little contact tab for the antenna lead (inside the housing) out a little bit, so that it would make a more solid contact with the mast assembly.
Once it was all back together, I installed it and tested it. It works great now! Before, it would make a loud whirring noise when extending / retracting, now it's nearly silent. And of course, the reception has improved 1000x over what it was.
Thanks to all who helped
