Old 03-25-2009, 04:58 PM
SVX 05 SVX 05 is offline
CHECK ENGINE light on
morning all, just got my car back from service CHECK ENGINE light was and still is flashing.. but they have not been able to find problem . it has been suggested it could be a need for 'Knock sensor or Oxy sensor . has anyone had similar problems ?
Old 03-25-2009, 05:04 PM
legacyau legacyau is offline
Re: CHECK ENGINE light on
where did you get it back from? and did you get charged ? if theyre a dealer you need to give them a rev about it, they have the equipment to check the codes, if the light is on there will be a code stored in the ecu
regards cam
Old 03-25-2009, 05:06 PM
yes monitor code check done . found 2 faults that was the 2 . other than that nothing
but it only came on for a few seconds . has done for a week
Old 03-25-2009, 06:25 PM
As they have checked the codes, they should be able to say what is producing that code. Maybe Knock sensor or O2 sensor is a bit vague.
It is probably a O2 sensor. What model is it obd1 or obd2?
Old 03-26-2009, 02:53 AM
Smile Re: CHECK ENGINE light on
Harvey, how you doing ?
you were my saviour a few years back when I was in Qld. with the aircon problem.
these are the parts they suggested it may be .
knock sensor 22060aa031
or
oxy sensor 22690aa180
buy they are not sure. there are less svx's in Melbourne so harder to find someone who knows them .
Joann
Old 03-26-2009, 05:43 PM
or
Joann
Giday Joann, yes I remember.
There are two of each O2 sensors and Knock sensors, one for each bank. I think you should pull the codes yourself to see which sensor is the problem.
You can find how to do it here,http://www.subaru-svx.net/photos/files/How-To/14337.doc
and here
http://www.subaru-svx.net/photos/files/How-To/14374.doc
It's not hard to do, just look behind the right hand side kick panel, it will just pull off.
Old 03-27-2009, 01:30 AM
dynomatt dynomatt is offline
Joann...I think I gave you some bits didn't I? Matt...who was from Brisbane, but is now back in Canberra!!
Old 03-29-2009, 05:50 PM
Thanks Harvey, will get my other half to check it out.
Joann
Old 03-29-2009, 05:52 PM
Hi Matt,
yes I did get some parts from you . Both are working fine.
seems we both moved out of Qld ...
