Old 03-12-2007, 08:37 AM
joburnet joburnet is offline
Electric Turbo Charger
I've had this idea for a while and just found a company that makes an electric turbocharger.
http://www.electricchargers.com/
While there product looks like a POS, it almost has to be for $100, I think it's a pretty sound idea. It's not as efficient as using exhaust has or being belt driven but it's a whole lot easier to install and should be a whole lot cheaper.
Has anyone seen this before or have any information on a quality electric supercharger?
Old 03-12-2007, 08:45 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
no wait,
Brian
Old 03-12-2007, 09:08 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
garbage. I cant believe people still buy into that ****.
~Phil
Old 03-12-2007, 09:12 AM
Do you have reasoning for that?
Old 03-12-2007, 09:13 AM
on a .8l engine it might have those kinds of gains... on a 3.3l that already breaths deep, it is merely a restriction
Old 03-12-2007, 09:19 AM
If you get an upgraded alternator you can have as much as 1200 Watts of extra power (100 amps extra x 12 Volts) when accelerating, that's enough to drive a pretty powerfull vacuum. Now take that power and direct it into the air intake and I could certainly see a significant power gain.
As I already stated that $100 thing is a POS, but that doesn't mean that something similar couldn't work.
Old 03-12-2007, 10:30 AM
Reminds me of the leafblower mod
Might make a difference to my Taurus, which was factory tuned with a 10 pound sledgehammer (a whopping 145 HP out of 3L), but not to a better engine.
Old 03-12-2007, 10:42 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
dumbest idea ever
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 03-12-2007, 11:13 AM
JaySVX's Avatar
JaySVX JaySVX is offline
I do. a turbocharger or supercharger works on a simple principal: Forced Induction.
That tiny fan cannot create any actual "pressure", i would go as far as to say it's more of a restriction, because the engine will draw air in faster than the motor can spin the tiny fan. The only practical electric super-charger i have seen is by Thomas Knight, on a nissan altima. He had to have 6 special batteries and 3 rediculiously complex blowers. It worked, only as long as the batteries could sustain it. Once they ran out, it did not work. The alternator could not produce enough current to keep them going at all times, so he installed a switch for it. You can read the article here:
http://www.turbomagazine.com/tech/04..._supercharger/
Nothing for under 2000+$ will give you any performance boost, unless you build hte parts yourself, by hand, but then you pay for it in hours of labor. In short, you get what you pay for.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 03-12-2007, 11:50 AM
Thanks for the link, that guy is taking it pretty far but it's cool to know what is possible.
Old 03-12-2007, 11:53 AM
Phast SVX's Avatar
sure. that fan can push maybe 100 cfm. Your engine breaths 230CFM stock, and my turbo setup at 8lbs breaths 570ish cfm. Its a freaking restriction. Better though, test it out and see if it works, then you will have learned the hard way.
~Phil
Old 03-12-2007, 11:56 AM
Phast SVX's Avatar
My turbo spins at 23,000RPM. the HEAT created from compressing air would melt the plastic blades on that fan, and would most definetly melt the maf.
phil
~Phil
Old 03-12-2007, 12:05 PM
JaySVX's Avatar
I found the article in a magazine i read ages ago when i was in the air force. The only reason i had any interest was because i owned hte same make/model altima, and his seemed very nice looking. I just did a search for supercharged altima and it popped right up.
In short, anything less will do more harm than good. Unfortuantly, there is no shortcut when it comes to this, as is most things that are worth while, else we'd all be running boosted svx's.
Old 03-12-2007, 12:26 PM
I figured that was the case but I wanted more information. This kind of thing may work pretty well with hybrid vehicles as they already have a large enough battery to power an electric supercharger.
Old 03-12-2007, 12:36 PM
Apparently this electric supercharger is available for purchase for any vehicle and is ideal for hybrid vehicles. Prices start at $1695 and units can get up to 750 CFM, which would be more then enough for our SVX.
http://www.boosthead.com/updates.php
