View Poll Results: Select your OEM strut experience | |||
Bought OEM rear strut after 12/10 and it is OK | 1 | 25.00% | |
Bought OEM rear strut after 12/10 and it failed | 0 | 0% | |
Bought OEM rear strut between 7/05 and 12/10 and it is OK | 0 | 0% | |
Bought OEM rear strut between 7/05 and 12/10 and it failed | 1 | 25.00% | |
Bought OEM rear strut before 7/05 and it is OK | 0 | 0% | |
Bought OEM rear strut before 7/05 and it failed | 1 | 25.00% | |
Bought OEM front strut after 12/10 and it is OK | 0 | 0% | |
Bought OEM front strut after 12/10 and it failed | 0 | 0% | |
Bought OEM front strut between 7/05 and 12/10 and it is OK | 1 | 25.00% | |
Bought OEM front strut between 7/05 and 12/10 and it failed | 0 | 0% | |
Bought OEM front strut before 7/05 and it is OK | 0 | 0% | |
Bought OEM front strut before 7/05 and it failed | 0 | 0% | |
Multiple Choice Poll. Voters: 4. You may not vote on this poll |
Thread Tools | Display Modes |
OEM Strut Poll
I am going to try and make it so people can select multiple choices for multiple cars.
Re: OEM Strut Poll
You could make a survey on another site like survey monkey. Forum poll options are usually pretty limited.
Re: OEM Strut Poll
Replaced 2 rear struts with Subaru goods on my silver SVX March 2012 @ 186,200 miles. No trouble to date, but way too soon for a definitive conclusion.
dcb |
Re: OEM Strut Poll
Just a reminder guys that you can enter multiple choices. So if you had rears that failed and fronts that didn't, you can enter both.
