Is my Tranny failing??
Is my tranny failing already? Had tranny rebuilt last september, and car sat all winter. Just started driving it the past two weeks, about 600 miles total, and last night on way home from work while cruising at 65mph tach at 2200rpm tranny would flare up, rpms jump up to 3000 breifly and back down. Did this several times. Its still under warranty. Should I just not drive it, dont want to break down in it on a long commute.
1995 POLO LSI 76K MILES SOLD |
Re: Is my Tranny failing??
take it back before doing anything else. if it's under warranty they may be able to fix what's wrong with it without rebuilding it. could be as simple as a leak so it's low on fluid.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
Oh boy Dan ! Could that be the converter not locking up? Somethig is slipping I know on my pearly it was real easy to make it drop down a gear by adding a little gas pedal.
It does sound like converter lockup/unlock... I think the rpm difference is 500...IIRC
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
IF THE TRANS IS ALLOWED TO CONTINUE TO SLIP, YOU WILL KILL IT. And pretty quickly too. Keep the shifter in a lower gear to prevent it from slipping. Every time it slips, the longevity of the trans is reduced.
I would take it back to the re-builders, tell them what is happening and what I suggested, till then, leave the shifter in 3rd. Harvey.
Harvey thanks for the info. Fluid is full and clean, as one would expect with only 600 miles since the rebuild. Amsoil synthetic ATF was used. I dont know if should drive it in 3rd as you guys suggested or not drive it at all until I take it to the tranny shop. Just for the record this car still has an idle problem. Keeps throwing code for Idle Control Valve. It idles eractly and high most of the time. It will usually throw the code when put in park and left to idle high around 1300rpms. I bypassed the idle control valve by connecting a separate blocked hose from the upper port of the throttle body to the lower port of the snorkus. I had done this on OT's advice to prevent the car from stalling without keeping foot on throttle. It worked, but the issues with the eractic idle continue. I have also gotten a code for EGR. Dont know if this is related or has caused the tranny problem described. I had been planning on driving it to OT's sometime soon for an engine reseal and fixing of the idle issue, but now with this tranny issue, driving 400 miles doesnt seem smart. With my luck with svx's, Id be stranded somewhere with a failed tranny. My problems never end. I just got the car thru emissions last week, in between the CEL coming on, and renewed my registration. Now this. If I didnt love the svxi so much I would have rolled it off a cliff long ago
With a diagnostic interface like the ECUTuner you would be able to monitor for example your TPS signal and the TC lock up solenoid cycle..... with these two bits of info you might be able to tell if there's a problem within the trann or not.
It's free to download - only the cable will set you back a few bucks. Tapani |
Tapani, where do I get it and how much
http://www.ecutune.com/ECUtuner.htm
It's free - and Mike is here on the forum - see ECU Tune Projects area Tapani |
Conn, I havent used cruise yet, may try it tonight on drive home. I will say it only seems to happen when drivng at steady speed, not accelerating. If I were a betting man, I would say the idle issues have something to do with it.
