Cylinder 6 Misfire :UPDATED:
So. the Car: EG33 powered XT6 (like huck). running STOCK SVX ECU, '92
the problem: Cylinder 6 DOES NOT FIRE. (as far as I can tell EVER, explanation in points below) what I have done: (1) Pulled codes: 55 (EGR TEMP) not related as far as I can tell, don't even have O2 Codes (2) Pulled injector leads till i find the one without a miss (turned out to be #6) (3) Swapped coils with known good coil, to no avail (even used Spark checker, no spark on #6 no matter what coil I use) (4) Swapped injectors between #4 and #6, Still misses on #6 (5) Checked Continuity on BOTH wires from the coil connector to the Ignitor (tested good) (6) Checked Continuity on ALL wires FROM Ignitor to ECU (tested good) (7) Swapped Ignitor with known good unit (still misses) (8) Swapped ECU with Known good Unit (still misses, Codes pull the same, always a 55) (9) might be related.... Replaced Crank Angle sensor, cleaned both cam angle sensors of debris. (10) Checked Compression. All were over 120 (11) checked plugs, All but #6 looked Tan (propper) #6 was WHITE, Replaced #6 plug in fear of a bad unit and checked after a spirited drive...Still White (NGK Iridiums) (12) Searched all over for anyone having the same problem....nada Supplemental info: Since I did the engine swap i have had the miss... I did NOT hear the engine run in the original SVX, (was a sad SVX, all because of a trans, someone parted the whole thing, I got it with no trans, diff, lights, and wanted interior parts). The car is DEAD reliable, Starts always the first key turn. Every once in a while i'll get the idle lope in Neutral or coasting clutch in... Only every once in a (long) while does it stall because of this. i am sure there are things I am missing... BUT any help would be very appreciated Rusty
SVXT6 (Pearly) just got running 201,000 (body) 105,000 (engine) Honda FT500 Ascot [Red] Last edited by Ironhydroxide; 06-20-2011 at 09:39 AM. |
Re: Cylinder 6 Misfire
I am assuming that No.6 is the rear on the US drivers side.? I don't see any vacation of power getting to the injector. The White No.6, could be a very lean mixture, or that no fuel is present when the spark happens. Check that there is 12V at the injector and that injector is actual passing fuel. Harvey.
I'll certainly check this..... Buy I can physically hear the injector clicking when I re attach the lead, and stop when I remove it.
I am quite sure it is something to do with the coil..... But have no idea what or how
SVXT6 (Pearly) just got running 201,000 (body) 105,000 (engine) Honda FT500 Ascot [Red] |
Got the sides mixed up, I am RHD. Harvey.
you can bench test the coil by supplying power and tapping the ground side to ground, easiest to do with a plug in the end that is touching ground. if it fires off the car but not in the car you have a wiring or signal issue.
When it has the Igniter grounding it, and the current gets to 4amps, it holds the current at that level, so it does not get higher. Harvey.
Um, no, REAR Left Side of the engine. IIRC the Engine goes as such
Front 2 1 4 3 6 5 Back OH, and another weird thing....While I was having Crank angle sensor problems (or when I pull the crank angle sensor out of the hole without disconnecting) the Engine throws TONZ of codes (which i would expect) BUT the interesting part. It threw EVERY Injector SAVE #6 (maybe because i had #6 disconnected while cranking because of the problem I've had).
SVXT6 (Pearly) just got running 201,000 (body) 105,000 (engine) Honda FT500 Ascot [Red] Last edited by Ironhydroxide; 05-18-2011 at 11:01 AM. |
Ignition module???
Ive swapped Coils(multiple), Ignitor, and ECU..... From the swap that's all the Electronics I have there in place for ignition (and is all that is in the wiring diagrams)
My mistake. I got turned around. I would still swap the injector to test it, that's the next thing I can think of.
Ok, see #4
