Old 12-22-2010, 06:41 PM
Huskymaniac's Avatar
Uses the ignore feature
K&n Hp-4001
Has anyone tried this oil filter? It cross references with the Purolator 30165 which is supposedly compatible with the SVX.
http://cgi.ebay.com/ebaymotors/ws/eB...4766&viewitem=
It is a larger filter so it should have a higher capacity and lower flow restriction. Not sure if that matters unless one is doing some cleaning using either HM oil or an oil additive.
Tony
Old 12-22-2010, 06:52 PM
Cam Cam is offline
Re: K&n Hp-4001
Try finding a filter compatible with the Porsche 944. Same thread and seal configuration. I think OT discovered they fit. Anyways, it holds more oil as well.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 12-22-2010, 07:58 PM
Re: K&n Hp-4001
And North America!, See, there was this ice bridge from Russia years ago, ( we did not call it Russia back then,) and I was bored and took a little walk!
Old 12-22-2010, 08:06 PM
Cam Cam is offline
Re: K&n Hp-4001
It's just too bad royal purple doesnt offer a filter for a 944...
Cam
'92 Ls-L Dark Teal
Old 12-22-2010, 11:10 PM
Re: K&n Hp-4001
This K&N filter is supposedly a re-badge of the Mobil-1 filter. I am assuming that it is a better filter than the Purolator, which is not a Pure-One. However, if one is changing their oil near the recommended OCI and they are not doing a cleaning cycle of any kind, does it really matter if the oil filter is better?
Tony
Old 12-22-2010, 11:55 PM
Cam Cam is offline
Re: K&n Hp-4001
Can't put a price on peace of mind
Cam
'92 Ls-L Dark Teal
