Old 02-26-2009, 11:56 PM
TheWheelMan TheWheelMan is offline
4.44 transmission id number
I remember seeing a forum awhile back on how to identify a 4.44 trans. i was curious if anyone could help me identify if I received a 4.44 trans for my car the id is TZ102Z1CAA-DG. Because after 2500 miles the front diff went and it binding up and crunching.
Old 02-27-2009, 12:25 AM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
Re: 4.44 transmission id number
Wait, you had a tranny in the car that only lasted 2500 miles and you're concerned that it broke because it wasn't the right ratio to match a 4.44 rear end or something?
If you put the wrong ratio gearbox in the car for matching the rear-end, it wouldn't fail in 2500 miles, it'd fail in more like 2.5 miles. I had a 4.44 tranny w/ a 4.11 rear end on my car and we knew it was wrong in less than 10 feet of backing out of the lift stall!
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
Old 02-27-2009, 01:19 AM
http://www.subaru-svx.net/forum/show...T+Transmission
Old 02-27-2009, 02:28 PM
sperry's Avatar
Lots of discussion about 4.44 ratio trannys here as well:
http://www.subaru-svx.net/forum/showthread.php?t=36775
