TCU pin assignment
After swapping out TCU in our 92 with 444 transmission, having problem with VSS1 not reading. Assuming I have a connection problem with the wiring connectors to the TCU or poorly soldered 28 pin dip, anyone know which positions are related to VSS1?
It is difficult to swap TCUs due to the location, trying to minimize time spent upside down...
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
Re: TCU pin assignment
I was under the impression that you weren't supposed to swap TCUs when doing the 4.44 swap. Or did you swap it out because it was bad?
Swapped in unit with ECUtune ROM
Can you confirm the speed sensor still works?
That sounds like a great idea, how do I test it?
When I was testing out the 5spd after I first installed it, all of a sudden the speedometer quit. I ended up taking the sensor out of the 4EAT and using it in the 5spd.
Basically, do you have a working sensor you can borrow?
