My SVx is not as fast as I thought....
I wasn't sure if Technical was the best place to ask this question, so here i go anyway. When I got my car it was for the looks not really for the muscle. The Svx has 230hp right? Why does mine feel like it has 130hp. Is the svx tunable? What do i need to start doing to build up the motor?
jcimos |
Re: My SVx is not as fast as I thought....
Welcome to the Network family! There are plenty of existing threads that will directly address your questions. Just let the "Search" feature be your friend.
-Bill
Main reason is it's 230 HP in a nearly-4000lb car with AWD, an automatic transmission, and a 3.54 final drive ratio. Good for cruising comfortably on the highway, and having enough power to still be fun, but a rocketship it is not.
There are ways to tune it up, the search function will benefit you greatly!
One thing you will find if you intend to up the power of the car beyond stock, well running, HP levels, is that the cost increases almost exponentially the farther you go. Intake and exhaust might get you up to ~250 HP, but even that will likely cost you $1500, and then you'll max out your stock MAF. That means it's either time for an ECUTune chip, or a manual transmission swap and Hydra engine management. Now you're well into the thousands of dollars. It goes on from there.
The realistic fact is, if you want something that will leave clouds of tire smoke at will, buy a different car. Getting more power out of this one is incredibly tedious and expensive.
Okay, well this is whats in my svx already. It has a 5 speed wrx tranny, dual exhaust MegaFlow system, fuel pressure regulator, and a SAFAC II module. I always try to put premium and when i use mid grade I add octane booster. The check engine light is on and it is read code 23, something to do with my mass airflow senor i believe. Besides that no real tune. Could it be my SAFAC II needs to be tuned?
Jcimos |
SAFAC are you using and how did you get it to work with the SVX? I have never heard of anyone using one on a SVX.... BTW if you are throwing a code for a faulty MAF that would affect your performance tremendously....
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 Last edited by sicksubie; 02-11-2009 at 12:57 PM. |
Yeah your MAF code would be the absolute first place to start. Thats the holy grail of air/fuel management for the fuel injection system.
Okay, what's a SAFAC?????
Harry
newsvx 1992 SVX LSL, #1215 1997 SVX LSi, #370 "I live with fear every day. Sometimes she lets me go racing." "Getting Older and Slower" Locker: http://www.subaru-svx.net/photos/user.php?newsvx |
1991 SVX L JDM |
Chris, I thought he had a 4.11 5spd. That's about where my car runs on the highway.
1991 SVX L JDM |
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
If I had the money.....Maybe that should be the network's slogan?
Super AFC (Air Fuel Controller). Lets you adjust your AFRs. If you're a good tuner and know what you're doing, it has its uses on a budget build. If noob settings are applied though, motors will grenade. Guess what usually happens SVXs already run pretty lean from what I've read, you think it's been set to run any leaner than stock?
That made me lol |
It's heavy, and its geared to high....
put some lower gears in it and it'll wake it up...
