Old 09-30-2007, 11:08 PM
lilbrudder lilbrudder is offline
i can make it on my oooowwwnn!
what kind of diff. fluid to use?
can some one point me in the direction of oil to use in the front and rear differentials? can i use Subaru Extra-S 75w90? or does it take atf?
Old 09-30-2007, 11:42 PM
jeffast jeffast is offline
I kill more trannies then god
75w 90 will work fine, but for the rear you need to mix lsd additive in with the oil, or you will probably damage the rear end. you can get it at most autoparts stores or the dealer sells it for under $10.
my $.02
1991 xt6 eg33?
1993 gc track car
Old 10-01-2007, 02:24 AM
Originally Posted by jeffast View Post
75w 90 will work fine, CORRECT!
but for the rear you need to mix lsd additive in with the oil, or you will probably damage the rear end. INCORRECT!
my $.02
Our Limited Slip Differential rears are a sealed viscous fluid type, and require no such additive.
Old 10-01-2007, 05:51 AM
dcarrb dcarrb is offline
The spec is in the owner's manual, if you have one. I'm pretty sure a slightly different weight is listed for front and rear and second that no special limited-slip additive is specified. DO NOT use transmission fluid.
dcb
Old 10-01-2007, 03:53 PM
yeah, i don't have a owners manual unfortunatly. is anyone for sure about slightly different weights? i would love to just get a barrel of subaru extra-s, i heard it will do wonders for my LGT too.
Old 10-01-2007, 03:56 PM
well learn somthing new evreyday
1991 xt6 eg33?
1993 gc track car
Old 10-01-2007, 04:03 PM
SomethingElse's Avatar
word words wording
wish i knew that 3 rearends ago.
Eric
Old 10-02-2007, 05:48 AM
Per the owner's manual:
Front differential—(operating temperatures -30 to +90F) 80W/90, capacity 1.3 US quarts
Rear differential—(operating temps as above) 75W/90, capacity 0.8 qt.
