Can anyone tell me what this is?
I was working on my brakes and when I backed up I saw this on the driveway.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. Last edited by SVX_MY_BABY; 02-19-2010 at 04:31 PM. |
Re: Can anyone tell me what this is?
This post was brought to us by the number..... 30....and the color.....black
(good luck, Idk what it is)
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! |
It's hard to tell what it is without a size reference. If I were to venture a guess, I'd say a drain plug of some sort. Possibly from under the spare tire or in the front frame rails by the valve covers.
Id guess a weather plug from the chassis somewhere, similar to the one thats removed to get to the driver rear spark plug.
It's one of the frame rail plugs. I pull mine every fall to fill the rails with rust inhibitor. The SVX has more built in chassis plugs than any other car I've ever seen. Just look under the rails and you'll see a circular hole that matches the plug.
