Old 11-19-2008, 11:12 PM
mo_thug_85 mo_thug_85 is offline
weird sound
hello i am getting this like wine or rub sound from my tranny it works fine and shifts perfect and runs great just a wierd noise
Old 11-19-2008, 11:49 PM
Hondasucks's Avatar
Subaru Technician
Re: weird sound
Any more information? Does it change relative to the speed of the car or the speed of the engine?
1986 VW Jetta
Old 11-20-2008, 09:16 AM
Re: weird sound
i think i found some thing that sound like the same thing when the metal from the exhast is rubbing on the drive shaft
Old 11-20-2008, 08:09 PM
Hondasucks's Avatar
Subaru Technician
Re: weird sound
If your car has stock exhaust, and it's rubbing on the drive shaft, check your engine and transmission mounts, make sure they aren't loose or cracked, as that will cause the engine/trans to shift around, which will make noise, as well as eat drive shafts & axle shafts (The U Joints in the drive shaft are not serviceable, if they go out you have to replace the whole shaft at ~$400, unless you can find a drive line shop that can replace the joints.
1986 VW Jetta
Old 11-20-2008, 09:33 PM
Re: weird sound
Does it sound like a card in bicicle spokes?
Old 11-21-2008, 08:01 PM
Re: weird sound
ummm i am just buying it does any one live in western pa
Old 11-21-2008, 08:45 PM
Wikedjuggalo's Avatar
Rebuilding
Re: weird sound
Now you steal my descriptions lol. Lets hope not.
But OP trying being a little more informative does it go with RPM's and not happen when in neutral moving? Try driving it and then lay of gas go into N (kinda like if you did it by accident) and see if it disappears.
Old 11-21-2008, 08:50 PM
Re: weird sound
ok i will try it sorry i only test drove it 1 time i will try again
Old 11-23-2008, 11:24 PM
Re: weird sound
it sound like a wine or like a rub noise. but the tranny and everything seems fine. i think i will change the tranny filter and oil
