Old 12-07-2004, 07:43 AM
red95svx
Tire size question
Anybody ever run 215/60/16's? I have a lead on some cheap snow tires but I'm not sure if these will work. I see that the 97 models used 215/55/16's so I'm guessing a little bit taller wouldn't hurt.
Old 12-07-2004, 08:00 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
You are looking at approximately 1.3" difference on diameter from stock size. I don't see why it would be a problem as long as you do all four. Your speedo will be off though.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 12-07-2004, 08:02 AM
Word to Yo Motha
I run 205-55-16 for snow tires. These are only a 0.02" difference on diameter. Just fit on stock wheels, and are so skinny they cut right through the snow.
Collin
1995 L AWD
Locker
Old 12-07-2004, 10:41 AM
red95svx
No problems on 205's huh? I have access to a set of slightly used 205/55/16 snow tires....maybe I'll go with those. Thanks for the help.
Old 12-07-2004, 10:43 AM
can't go wrong with the 205/55/16s
Old 12-07-2004, 10:51 AM
Any time you install a taller tire, its that much harder on the transmission.
Old 12-08-2004, 09:37 AM
red95svx
Why is that? Is it that much tougher to roll tires that are a bit taller than normal?
Old 12-08-2004, 10:15 AM
http://www.subaru-svx.net/photos/fil...yIII/14768.xls
That would make it 5.2% more travel for the same rpm, or 5.2% harder to get started.
The initial moving of our 3580 pound vehicles is normally the hardest on the transmission.
For example, try pushing your car on the level in an empty parking lot, its a bear to get started, but once it gets rolling, you can run with it.( The same idea applys to the friction materials inside the transmission, holding drums from moving, and such.)
More simply put a shorter tire gives a mechanical advantage by not having to move a fixed weight as far.
Ps; Thanks again Larry for your chart.
Old 12-08-2004, 12:58 PM
any answer to why subaru put a taller tire on 97MYs?
Old 12-08-2004, 01:17 PM
Only Subaru knows, but its 1.8% taller, not 5.2%.
Old 12-08-2004, 03:34 PM
I currently run 215/55-16's for winter tires...slightly narrower and slightly taller. I also crank up my coilovers for max clearance.
Even with the extra height the slush/snow still packs in the fenders and rubs on the tires.
Old 12-09-2004, 02:24 PM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
Yes the tire is taller, so the initial “start” may be harder, the foot print if the tire is narrower, so over all friction/resistance is less.
You will get better mileage with a taller narrower tire, which means the car is doing LESS work, not more.
Yes?
My $.02
BTW- Nice Chart/program app!
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 12-10-2004, 01:06 PM
I don't think there's an easy way to determine the effect of narrower tires has on fuel economy. This is especially true if you are also changing the height (or brand) of the tire.
Old 12-10-2004, 01:56 PM
Royal Tiger's Avatar
Certified Porschephile
I asked about why they switched from 225/50-R16 in 97 a few months back on here, and the answer I got was because they were fazing out the SVX and it was more expensive to get that size from Bridgestone. Try searching for that thread. I think I also asked about color choices if that helps find it.
Old 12-13-2004, 12:19 PM
drivemusicnow's Avatar
Poor College Racer
Yes?
My $.02
also it would be much harder to guesstimate mileage considering the odometer would be off a certain percentage.
basically taller tires has a similar effect as a taller differential. very similar in effect. slower overall acceleration, higher top speed, and the like.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
