#1291
Re: SVX Engine cooling "Again & Again"
Sensors - basically see svxfiles' post. The two sensors look to me like the stock coolant temp sensors.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by icingdeath88; 07-28-2012 at 11:11 AM. |
#1292
Bill
#1293
So we've pretty much sorted what needs to be done to solve this issue with the bigger thermostat cover and proven it's worth on the track. However a minor issue remains and this is the passenger head exits hotter than the driver head (Australian cars). Tony has logged this at being 10'C difference. This really isn't an issue for 99.999999% of people but it can easily be fixed if you're bored and or just want to do a mod. Why not nessecary - recently my ecu read temps never going above 88'C after 65 laps @ a circuit with a turbo EG33 and the ecu reads the hotter head... so I could get away with this forever.
Anyway the temperature difference is due to the pressure of the passenger head having flow restriction due to having to force it's way to the radiator. The driver side has a much easier route. Also note the EJ2X outlet is far smaller than the EG33 head outlet. The EJ2X outlet on each head is 26 mm, (1062 mm^2 area total) going out a 30mm outlet (707 mm^2 area). The EG33 is 29 mm (1322 mm^2 area total) trying to get out a 30 mm outlet (707 mm^2). So what if we double the outlet and make an easier path for the passenger side head... so today after chatting with Tony I made this up.... yes I know, I spend all my time welding steel and none welding ally so my ally welding sucks giant dogs balls. However this is just a beta version. They will both run into a Y-piece merge that feeds a 46 mm radiator inlet up top, I'll do that with stainless - far easier for me to weld Basically all that it does is give an far easier exit for the passenger head water. Last edited by bazza; 08-25-2012 at 04:36 AM. |
#1294
Bazza,
Yep, that weld is definitely a case of function over form (giant dog balls indeed!) ! Seriously, it looks like what you've done is a simpler version of what Tom did on Dan's car. Looking forward to seeing how this works out! Bill
#1295
Is that this one? I like the design - if the merge was bigger - 46mm ID or even it would be perfect - although it's hard to tell what size it is, could already be that size? I think this will be the perfect design, 2" ID even better than 46 mm ID after the merge. Also for interest sake, going from 38mm pump inlet to 50mm pump inlet increases the cross flow area from 1135mm^2 to 1965mm^2... massive difference. Even 46mm is 1662mm^2. Last edited by bazza; 08-25-2012 at 05:59 PM. |
#1296
I almost miss the days of r&d.... almost...
Tom |
#1297
We need to find you a new way to mod a SVX Tom?
I got some ideas...
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car 86 Lifted GL wagon well over 600k miles on the chassis 98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires |
#1298
Yep, that is the first step in Tom's (TomsSVX) modification to the coolant system on Dan's engine. If you flips back a few posts (#1292) you'll see the finished product (lines tapped into the main lines). What I don't think you've seen is the inline thermostat housing Tom added in the return line (for that matter, I don't remember seeing pics of it, but then that's probably age on my part ;-) ). Bill
#1299
Over the last couple of months in between other jobs have been playing with designs for new top pipe which include twin thermostates for cooling. Also a change to the PWR radiator. I was trying to develop the design so it would acheive the following.
- Have a thermostate for each head. - Two pipes returning to the radiator. - Use a different type of thermostate, one that when open will close the coolant going to the pump throught the 2 small hoses. - Thermostates to be located as far back as possiable close to the head outlet. - In addiation I had been working on a new cross flow radiator design that could be built by PWR (then you guys in the USA could get it) but have since found a way to acheive the same thing with a top and bottom tank design still made by PWR. - Review pressure loss in the sytem and attemp to reduce that loss so the system can cope with the higher flow of the pump running at 10k. Current engine means that 1/2 of the pressure loss in the system is from the back top of the block were the coolant comes out of the heads. When I get it onto this issue I will post updates. Tony
#1300
I'M planning to built my own thermostat cover but just to be sure It's 45mm ID? and your OD is 50mm?
thanks |
#1301
My cover is 2" (~50 mm) OD. However the radiator outlet is 46mm OD so I step down slightly.
#1302
ok, and somebody know if the oem housing( not the plastic one) of the wrx, sti ,ez30 are bigger than the eg33? |
#1303
Tom!
Can you post a pic of the inline thermostat housing - and specs for it - that you used on Dan's car? Thanks. Bill
#1304
Guys just about finished a thermostate housing that welds to the end of the top pipe along side the power steering pump. Have been stuffing around with the GCode on the CNC lathe so I can run up a number of these units at once as I will fit them to all my cars.
See if we can get photos up today. Tony
#1305
Here is photos of the top aluminium thermostate holder.
As you can see it has the following advantages:- Its welded to the top pipe, Its tucked away from the power steering pump etc, The thermostate is easly accessiable. Doesn't effect the rest of the engine plumbing. And you can chose your top pipe size by changing the out let cover. Its a really neat and tidy soluation for engine reving up to 8K. Happy to answer any question, I will need to discuss this with Bazza but we maybe prepared to sell units to others. If you are interested let Bazza know and depending on demand we will consider selling them to others. Haven't sorted a price yet but we don't aim to get rich. Tony Attached Images
