Old 09-16-2008, 08:25 AM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
Problem with skid plate bolts
Anyone ever had trouble with the bolts that hold the skidplate/undercovering piece on?
My whole undercover fell off while driving too fast because the holes in the plastic had worn too big for the little bolts to hold them on w/o washers.
I'd like to put it back on with maybe some upsized bolts/washers, but there are still 2 of the bolts stuck in their positions.
They spin freely and won't tighten or loosen, they just spin loose in there. Could it be these are the wrong size someone stuck in there at some point?
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
Old 09-16-2008, 10:24 AM
Old Fogey
Re: Problem with skid plate bolts
Looks to these old eyes like the final portion of the bolt is not threaded, allowing it to just rotate freely. Have you tried exerting upward pressure on the bolt with a prybar, while unthreading it, to get the threads started?
Glenn
Old 09-16-2008, 10:26 AM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
I've not had that problem with them, but I have had 2 that seized up and the heads twisted off.
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 09-16-2008, 10:48 AM
CorSVXette's Avatar
Classic SVX
You can do what I do/did. After getting the bolt out use small plastic wire ties to hold it up. When you need to change your oil you just cut them. They are very inexpensive and they work just fine
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 09-16-2008, 06:39 PM
kwren's Avatar
kwren kwren is offline
I believe there is some kind of insert that each of these bolts actually screw into.
I put washers on the bolts on mine that would keep the thing from coming down over the bolt heads.
Works great for me.
Old 09-16-2008, 07:26 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Every single bolt on my skid plate got the heads twisted off so I have no plate and I have to drill out the studs left in the holes
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-17-2008, 01:38 PM
Was MacGyver
Works great for me.
Yeah definitely my plan once I get these two stubborn ones off. Besides, I need one of them to figure out what threads on need on the new bolts I'll have to buy.
Troy
Old 09-17-2008, 02:06 PM
kwren's Avatar
same threads as in the bottom of the bumper cover... the plastic covers for the timing belt section...
Old 09-17-2008, 07:20 PM
I think I have one of those bolts and about 8 zip-ties holding my skid plate and wheel well skirts on, the rest of the bolts have the heads twisted off. I had one skirt pull loose and end up under the wheel at highway speeds. That smelt nice.
