Q Regarding EGR/Engine Performance/Tuning
This sort of popped into my head the other day, maybe you guys who have looked into the engine's software can help me out here.
An EGR system basically siphons off a small portion of the exhaust gases and circulates them back into the engine intake, with the whole goal of reducing emissions of Nitrogen Oxide, with a few potential side benefits. When I took a look at the EGR system on the EG33 I got to wondering just how it applies and how well it was factored into the engine's software. If you take a look at the system, you'll see it only works with the #5 cylinder (rear passenger side). The pickup is off the exhaust manifold, just after the #5 exhaust port, before the pipes have merged, and the dump is into the intake manifold, just before the #5 injector stack. This to me basically indicates that cylinder #5 is going to be developing less power than the other 5, because it has less oxygen coming into it. However, does the engine's computer know this? In a nutshell, are the injectors compensating for there being less burn-able air in that specific cylinder, or are all 6 injectors working at the same duty rate? If they're all the same, then that cylinder will be running relatively rich (less air, same fuel), and the others a bit lean (same fuel, but perhaps a bit more air than expected). I don't know if finely tuning (with a Hydra probably) for this would have much of an effect on HP and performance levels, since EGR's are usually closed under load, but maybe during daily driving it would have a small effect. (mileage mostly). This is more to stop my own head scratching than anything else.
Re: Q Regarding EGR/Engine Performance/Tuning
the egr inlet on the intake manifold goes through a cast passageway to a pair of holes each directly in front of the throttle body openings so that each plenum gets equal egr no matter the position of the iris butterfly.
Ah, I see. Thanks for clearing that up. I've never taken the intake off my car, so I've never had a real in-depth look at it.
Is there any performance or mileage gain in disabling the EGR system? Any negatives besides environmental?
As far as my experience, mine has been stuck closed since last year and I get great gas mileage..... more than the EPA 25 on the freeway..... so I know it doesnt hurt mileage at least....
I get 30 with my EGR working fine, but a bum O2 sensor.
