Transmission flush
I know a search on this topic would probably bring up volumes of info, but wondering what the latest line of thinking is.
My local Subaru shop is strongly recommending I get the tranny flushed. The fluid is definitely ready for replacing. I know in the past members here have been against getting an actual "flush" for fear of stirring debris up inside there and causing problems. I've read some past threads about just changing out the fluid fairly often. But I can't find anywhere that details exactly how to do it in an idiot-proof (me) step by step. How much fluid, what kind, where does it drain, go in, filters, etc, etc? Or is it worth it for me to just pay the shop $120 to have the tranny flushed and all fluid replaced at once and good to go for a long while?
Troy 1992 SVX LSL "Serenity" 250,000 miles! I don't care, I'm still free, You can't take the sky from me... |
Re: Transmission flush
Starting at 42,000 miles, I have had my tranny fluid "exchanged" every 25,000 miles by my Subaru dealer and have not had any problems to date.
The SVX Master Tech told me that, like most good flushing machines, it uses the transmissions own oil pump to move the fluid. With the engine running, the old fluid is pushed out while the new fluid is drawn in. Actually its more of a fluid exchange than a flush. It uses the power of the operating automatic transmission to push the old fluid out, while drawing in the new fluid. I believe they are using the T-Tech system. The mechanic connects the ATF hoses to the machine (which is filled with about 15 qts. of ATF. The car is then started and the exchange starts. The vehicle's own transmission pump regulates the exchange process, guaranteeing that proper pressure and fill are maintained. Using this much ATF guarantees almost 100% fluid exchange. Since there is no additional pressure used to in this process, other than the tranny's own ATF pump, I wouldn't think there is anything that would disrupt or dislodge anything. It is just moving fluid at the same rate it always did, only the fluid is always fresh. Still running strong at 119,000 miles... I use either Mobil 1 synthetic ATF or Red Line High-Temp Synthetic ATF. .
I am definitely of the opinion tha tit is worth it just to pay the $120 and have it flushed. Our shop has been doing flushes for a good long while now and have yet to cause one to fail because of "dislodging some crap in there" or whatever you want to say. Have it flushed, and put in a GOOD synthetic like Mobil 1, or my favorite: Amsoil, and you'll be set for miles of smiles.
I use Amsoil synthetic ATF in all my 3 cars trannies, as well as Amsoil severe wear fluid in the differentials on the SVX. 75w-90 or whatever it is, I forget off hand...Anyway, runs like a top.
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
Once you've got a good external filter you shouldn't need to flush. just change fluid and filter a couple times. plus a "filtermag", which i'm sold on.
I agree w/ the amsoil. i just drained old, though still good reg dex and put in "super shift" which might be a lil to much, we'll see. suppose to help against slippage. i've got it in my trucks too. amsoil has a less racy trans fluids, "torque drive' and "universal atf", all synths. i've got synth in the diff's too. though the front needed some "slip lock" to quiet the chatter.
WFO! http://www.cardomain.com/id/Schralper "You all laugh cuz I'm different I laught cuz you're all the same." |
Troy
I would avoid the flush. I would exchange it or change it. I change (without dropping the pan) every 2nd or 3rd oil change. Some do it every time they change oil. There have been many menbers who have had their tranny fail right after a flush at a shop. If you want to discuss it further, let me know.
I am also a fan of the T-Tech machine as it works as svxcess describes. Being that I don't like others touching my car I installed an external filter so I can just change that instead. A filter and cooler will keep the trans fluid happy for mannnnny miles.
Oh, and for those who have had their trans fail soon after a flush, well it was about to go anyway. I use to make customers sign a waver if I thought their car would be harmed by a flush in any way. If the thing came in with black and/or burnt fluid, a ton of miles or didn't shift proper on the 'beforehand' test drive then I would rather loose the money than have someone pissed at me. Sadly most people out there just see suckers (car owners) with their wallet open and don't know enough or give a crap about the effects of such services and how the car may be effected by it. Quote:
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." Last edited by YourConfused; 07-02-2008 at 02:33 AM. |
One curmudgeon's opinion: Automotive "flushes" of every description were conceived solely to enhance the bottom line of the shop administering the procedure. If your transmission is routinely serviced (thorough gravity drain/clean filter/refill), getting every drop of old oil out by means of a powered exchange can't possibly be of any practical benefit.
dcb |
I agree with both svxcess and ensteele.
Most shops have a "trans flush machine" that used air pressure from the usually 100-120psi wall air supply. A simple drain and fill, or using a machine that ONLY uses the trans pump pressure is the correct way to go.
I've always been afraid of a flush but this sounds doable. John which stealer i mean dealer do you take it to.....
HENRY 92 SVX Claret(No More) 12 Camaro ZL1 89 Yamaha FJ1200 07 Yamaha FJR1300 "GO RAVENS" |
This is John Hoffman, using Toms computer. I ALWAYS go to OTs shop. Everyone should! So, this is really him, John Hoffman, not Tom, saying Come to my shop! er, his shop! Thats the ticket!
The first time I had it done, they used an air compressor to blow it back out from my cooling line. Needless to say I had excessive binding and later lost my rear transfer clutches, nor would they take responsibility for that.
Tim 1992 Liquid Silver LS-L Posted via Windows Mobile 6 Device |
The problem with just doing a "drain and refill" vs a flush/exchange, is just draining the pan does not get all the fluid out. The flush machine we have at work uses two hoses, you unplug one of the tranny lines (We use the one that comes out of the front of the transmission, as that is the one that comes from the pump) and the "dirty" line connects to the tranny side, and the "clean" side connects to the one that was disconnected from the tranny, that goes to the cooler. It uses the transmission to pump the dirty fluid out, and it's own internal pump to pump the new fluid into the tranny, but it is pressure regulated to the same pressure as the pressure of the fluid that is coming out of the tranny.
Drain and refill works if the fluid's not dirty, but it most cases a fluid exchange is the way to go. Don't forget to change the diff fluid as well. As for just changing the filter? don't forget, that the fluid does not just get dirty, it, like engine oil, also has additives in it that wear out over time. You wouldn't change your engine oil filter without changing the fluid too, would you? I would change mine every 30,000 miles, that $120 for a flush is a lot cheaper than a new transmission! And I've seen plenty of cars come into my work with 200,000+ miles on them (granted, not SVXes) and the tranny shifts like brand new, and they have had the transmission fluid changed regularly.
I am sorry that I do not always trust the guy "behind the counter", but I have seen my share of people who should not be there.
If the dealer/shop is doing the fluid exchange, does it generally include this as well? What's the procedure for this?
Remove the plug and you can drain out four quarts in ten minutes. If you have the time, leave out the plug for two hours and you might drain six quarts. If you remove the trans cooler lines from the radiator you will get a better drain. If you want to change the in the pan filter, remove the twenty, 10mm head, bolts that hold the pan on. Remove the pan and clean off the old gasket and gasket material. There are two black bolts that hold a 1/4" transfer line across the front of the trans inside the aria covered by the pan. Gently remove the tube by wiggling it while pulling it down. More oil will drain. Now remove the four gold 10mm head bolts that hold on the filter. Remove the filter. Install the new filter MAKING SURE THE O-RING IS ON THE INLET TUBE. Do not overtighten the pan bolts. You refill the transmission through the fill tube, where the transmission dipstick goes. It is on the drivers side by the firewall. You can use Dexron Mercon transmission oil of any brand that you like. You can use synthetic at about $6.00 a quart or generic at about $2.00 a quart. Hope that helps. Tom
