CEL code 24, stuck in limp home mode :(
I swapped out an older, lower compression engine with a newer engine which idled perfectly, ran strong. I've had a code 24 for almost a year now (wiring related), but, it's never put me in limp home mode.
Car idles PERFECTLY, idles a bit high, then drops down as it warms up. But it wont let me rev past 1500rpm or I hit fuel cut. Ideas? I'm pretty much ****ed if I can't get the car driving before saturday. ANY advice, help would be appreciated on how to bypass this code, or fix it. Should be noted. : AACV (brown/black) doesn't go anywhere off the ECU : IACV's white/red wire (at the plug under the manifold) goes to my canister purge control (at the ecu). |
Re: CEL code 24, stuck in limp home mode :(
is code 24 for the system that's right on the xover pipe on the engine, or the idle air control valve connected to the throttle body?
been doing some looking at the fsm and from some help from BRZ cory, it seems my code 24 is causing my issue. At least that's the only lead I have right now as to why I'm in limp home mode.
So far I have determined that my White and my Brown/white wires aren't 'emitting' the proper voltage. At least according to the FSM. Also according to the FSM the third wire, the white/red (on the iacv/aux air control valve) goes directly to the main relay. Does this mean it requires +12v? |
The insane part is, I'm stuck in limp home mode. I don't understand why either. This code shouldn't cause limp mode should it?
Rev limiter at 1500rpm and such. |
Anyone know of any way to reset my way out of safe mode?
So the AACV (the one on the crossover pipe) is not wired to the ECU? I would block off the TB and intake ports that it connects to in that case. Although it may work ok, since the bimetallic valve will warm up and gradually close as the engine warms up on its own, by design, the ECU controls a heater that can close the valve earlier than it would just from the engine heat, which I think is a good thing. With the AACV open, and no torque converter, my car idles around 1500 rpms, once it closes, about 5-600. AFAIK, disconnecting it shouldn't throw any codes, and shouldn't cause any serious issues, except perhaps some idling or startup issues in cold weather.
The EG33 IACV is a 3-wire pwm type. The middle wire is the +12V, and the other two wires are grounded at the ECU to either open or close the valve. So the middle wire does need to have a solid, +12V source. I would look into that if I were you, and see if you can improve the situation. I don't know if the code 24 would put it into limp mode though... Do you have a spare IACV or MAF to swap in to see whether that fixes it?
