Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Supercharged Projects
Old 12-21-2008, 10:19 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Electronic Counter Measures ON
Send a message via ICQ to Sov13t Send a message via AIM to Sov13t Send a message via MSN to Sov13t
Sov13t’s Engine and Supercharger Build
Prologue:
This particular project started around May of 2008. Around this time I finished all the minor things I wanted to fix up on the car and it was in great running order, so following logical progression I wanted to set a long term goal both for myself and my car – a challenge, if you may. At first, it was a vague, very general goal: make the SVX perform better. Thanks to numerous conversations with svxfiles (Tom) it started to shape up into a more defined yet very extensive set of objectives. I wanted to run the centrifugal supercharger and push the potential of our engines to new, perhaps even redefining levels. So, the R&D began…
Setting goals:
My current goals with this project are at 400+ all wheel horsepower. This goal went through multiple revisions, yet it is yet hard to say where we will end up. However, regardless of the numbers a parallel goal for this project is for the car to remain reliable. So we do not want to push 600+, having to start to worry about the transmission, axles, etc… just don’t want to deal with that… ***for now at least***
Summer – Fall 2008:
Throughout the summer and fall of this year Tom (svxfiles) and Tom (TomsSVX) helped me with finding proper parts for this type of application. And guess what? When both Tom’s come together and talk engines… it is absolutely overwhelming... That did happen at Pumpkin Carve 2008 – Which marked the ending of the R&D for this project. It was now time to start acquiring all the parts and pieces that were needed.
And so, I present you with the components/parts/pieces for this project:
Engine:
-8.5 C/R Forged, Gas ported CP Pistons Thermal and Friction coated
-Eagle Forged H-Beam Rods with ARP 2000 fasteners
-ACL Bearings
-ARP Head Studs
-Cometic Headgaskets copper treated
-ECUTune Intake and Exhaust Cams
-Custom valve springs
-Stainless Steel Intake Valves
-Inconel Exhaust Valves
-New oil pump, water pump, sensors
-New rollers, timing belt
-Ceramic coated Intake Manifold with some modifications for better heat exchange
Supercharger
-Jet Technologies T5 Supercharger - 1700 cfm
-Plumbing
Electronics and Engine Management
-Hydra EMS
-MadDad Gauges (Boost, Oil Press., EGT)
-Hydra EMS Wide band
-740CC Nismo Injectors
-GM Open Element IAT
Intake and Exhaust
-Tomyx
-Equal Length Headers
-Dual exhaust
Transmission
-04' USDM 6mt
-STi Flywheel
-SPEC Stage 3 six-puck clutch and pressure plate
Where are we now?
The majority of the parts for the engine and ems have been acquired with some exceptions that will be covered within the coming weeks. Also, the transmission and the intake parts have been running on my car for quite some time... however they are just as important for the overall picture... thus needed to be mentioned.
I believe slowly but surely this project will be moving into the assembly phase. So up next is the short block then hopefully the long block. Afterward it will be on to the supercharger. Updates will follow as we move along.
Budget
A lot of $$$
When?
Who knows?
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 12-21-2008, 11:14 PM
subbieatnz's Avatar
subbieatnz subbieatnz is offline
Re: Sov13t’s Engine and Supercharger Build
Awesum project. Post lots of pics
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired
1989 Vortex 6 Maroon
1983 RX Silver Grey
1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration
Old 12-22-2008, 03:56 AM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Good to hear you've got it all planned out already!
The news from OT about the ARP studs was a great relief!
Good luck on the project!
I shouldn't be to far behind you guys
Dustin
-Dustin
Old 12-22-2008, 05:59 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Dustin
Does this mean you're coming to Reading too?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-22-2008, 07:10 AM
odepaj's Avatar
Killer of threads
I'd like to. But as of right now, im not sure if I can afford it .
I deffinetly wouldn't have my "project" done by then.
Although I will be past the 200awhp mark
Dustin
-Dustin
Old 06-15-2009, 09:49 PM
Sov13t's Avatar
Some updates...
The short block...
The pistons....
More later...
Old 06-16-2009, 06:54 AM
Looking good! Where did you get the work done?
Old 06-16-2009, 07:38 AM
Tim's Avatar
Tim Tim is offline
We want more! We want more!
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-16-2009, 01:36 PM
CigarJohnny's Avatar
CigarJohnny CigarJohnny is offline
Send a message via Skype™ to CigarJohnny
Thumbs up Re: Sov13t’s Engine and Supercharger Build
Suh-weet!!!
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX)
Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting.
Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well.
You can tell the lack of craftsmanship by the wrinkles in the duct tape.
Old 06-16-2009, 03:02 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
copper gasket paint on the HGs?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-16-2009, 05:15 PM
-Bill
No, Bill,
that was only "a trick of light and shadow."
Teeheeheeheeheehee,snort!
Old 07-07-2009, 08:34 PM
Sov13t's Avatar
Yes copper paint was used on the cometics.
Engine nearing completion
Up next... is the fun stuff...
OT whats that whistling sound?
Old 07-07-2009, 08:51 PM
From Mad Max!
Goose: [describing the supercharged Interceptor that's idling, in particular the supercharger itself] You can shut the gate on this one, Maxie... it's the duck's guts!
Barry, MFP Garage Mechanic: [excitedly] She sips nitro... with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the ***** is born to run!
Goose: [looking at Max just staring at the engine] He's in a coma, man!
Old 07-07-2009, 08:52 PM
Tim's Avatar
Tim Tim is offline
More Picsssssssssssssssssssssss
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 07-07-2009, 09:42 PM
The "Speed Hole" Ceramic coated manifold should be back by the weeks end.
When it gets here will post some progress.
