Old 06-08-2005, 10:42 AM
914helo 914helo is offline
svx transplant
I've recently been going through my '92 engine and replacing seals, water pump, etc. I don't own an SVX, just the engine, so I've decided to put the engine in my Porsche 914. I've had my 914 for years but over a year ago pulled the old tired 95hp engine out and sold it and almost have it ready for paint. I need a new engine to put in and why not the 3.3L? A 230hp engine in a car with a total weight of 2300lb should be fun! I just bought an engine adapter from Kennedy Engineering to mate the 3.3 to my Porsche 5-spd tranny. I hope to test fit it in the engine bay this weekend, and then pull it back out and paint my car. I've gotten rid of the power steering pump and a/c as well. My main hurdles now are:
Alternator. Due to the small engine compartment size on the 914 I think I may have to flip my intake manifold around in order to fit the throttle body on. I won't have to worry about the power steering or a/c, but if I flip the intake manifold around I will have to fabricate a bracket to hold the alternator on. Should I even bother with a stock alternator? If I have to custom mount it (and I don't currently have a SVX alternaor) why not use one from any model that roughly fits and is rated closely?
Egr. I also don't have any of the egr components. My 914 is a '73 and I'm not going to worry about emissions. I still have an evap canister on my car and can use that, but will the car run OK without any of the Suby egr?
Management. Megasquirt maybe? Try and work with the SVX ecu? Wiring is going to be interesting.
I'm just in the test fitting stage and until I paint my car won't be really trying to get the car running. Any ideas would be greatly appreciated. thanks
Kent
Old 06-08-2005, 10:51 AM
Wow 10lbs/horse... That thing will scream.
I think if you had to flip the manifold around you might be able to squeeze the alt where the a/c used to be.
Old 06-08-2005, 11:02 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Awesome project!!!! I will post more when I have some time, but awesome!
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 06-08-2005, 01:06 PM
Good luck with your project. I'd love to see some pictures of this dilemma you're currently facing.
Old 06-08-2005, 01:28 PM
Word to Yo Motha
http://www.subaru-svx.net/forum/show...light=eg33+wrx
This thread may be of some interest to you. They flipped the intake and moved the alternator. I do not know much about stand alone ecu's, but I think that would definitely be the way to go. I would think it would be very difficult to utilize the SVX ecu. IIRC, Stevebsy has had experience with the Megasquirt. I think Mychailo is knowledgeable in this area as well.
Do keep us updated with your progress. I think it will be amazing! A 914-6 on Suby-Steroids.....
I don't think you need a vacuum canister and egr shouldn't be necessary if you go with an aftermarket ECU. Don't know about the EGR for sure though.
Collin
1995 L AWD
Locker
Old 06-08-2005, 01:59 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
So there's adaptors made for it huh? I know the ER27 from the XT6 is a very popular engine to put in the VW/Porsches.
Old 06-08-2005, 02:50 PM
I'll take some pictures tonight of my new adapter plate and clutch. The company I bought my pieces from specializes in adapter plates and clutches for VW/Porsche trannies. I wasn't sure if they could do one for the eg33, but they made one. Of course, I haven't put it on yet...
Kent
Old 06-08-2005, 03:43 PM
I've run without an egr manifold tube(from the exhaust manifold to the intake manifold) ever since I installed my first set of headers, about two years ago. No issues or c.e.l.s
Sounds like a GREAT project! Good luck with the wiring.
Old 06-08-2005, 03:49 PM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
Factory ECU all the way. Integrating a factory ECU is usually not a very big deal. The only real difference between an after market controller and the factory unit is that the after market one comes with instructions (which may not be very good anyway,) whereas the factory unit comes with nothing. Much to the advantage of the factory ECU is that extensive documentation and wiring diagrams are available, and once it's installed, it will work with no further headaches.
UberLocker
Old 06-08-2005, 04:14 PM
GreenMarine's Avatar
From POST-***** to LURKER
Again I post.....
Old 06-08-2005, 04:34 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
id go with the factory. tuning the aftermarket for what the eg33 needs would be a pita. and this way if you want to run any of ecutunes' stuff, you can.i have researched puting a ls1/lt1 in a fiero. most people use the factory ecu.
i wouldnt mind puting a 33 or a v8 into a fiero with a rebody so it doesnt look like pooh. i had a fiero striped down ready for transplant but i ran out of time and gave it to a friend who turned it into a dune buggy.
Old 06-13-2005, 08:27 PM
awsome project. Sounds like that car will scream. Good luck!!
Old 06-13-2005, 09:21 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Awesome! Post pics when you're able...
-Chike
2006 Steel Gray WRX TR (sold)
Old 06-14-2005, 12:03 AM
I took a couple of pic's of the adapter plate, flywheel, pressure plate, clutch disc and the car to be painted soon. I got stuck changing the steering rack on my wife's Explorer this last week and now I'm going to travel this week so next week I'll mate the engine to my tranny and test fit it in. I need the key measurements of trial fitting to see if I need to flip my intake manifold around and how my engine mount bar will line up.
Kent
