Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Audio/Video/Nav/Security
Old 04-22-2009, 02:54 PM
Speaker wire into door speakers
Hey I am in the process of putting in new speakers and am wondering how people ran new speaker wire into the doors. On previous cars I have always just been able to run the new wire through where all the stock wiring goes from the door into the car. However, on the SVX it doesn't seem like there's any room to run any more wires into the car that way. So just wondering how anyone else ran the wires while still having a clean appearance.
Thanks, Nate
Old 04-22-2009, 03:43 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Speaker wire into door speakers
I just spliced the new speakers wire into the old wire inside the door with no problems in sound quality.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 04-22-2009, 03:48 PM
That might be what I do but I guess I should have clarified, I have a set of components for the front and so I would have to splice into the wire twice in order to wire up to the crossovers.
Old 04-22-2009, 05:01 PM
Green1995SVX's Avatar
Nate-
I tied some wire to a coat hanger and fished it through the rubber boot. It wasn't easy, but there is room in there.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-22-2009, 05:27 PM
Nate-
Really!? alright, thanks for that, guess I'll just have to take my time.
I've got a ton to do to this car...I found a nice puddle in my trunk so I pulled the tail lights off, fixing the rust, installing a stereo... WIll it ever end
Old 04-22-2009, 06:11 PM
It never ends. Either you're working to make the car exactly what you want it to be, or you're fixing something to keep it just the way you want it to be. There is no known cure.
Old 05-05-2009, 11:37 PM
Speedklix's Avatar
Speedklix Speedklix is offline
Locker Link Solution
Nate-
Ditto... cut the hanger a bit so it isn't too much longer than you really need... think of the whole thing like a needle and thread. I use tape to wrap around the wires and smooth it out. Pull the car end of the boot/conduit off, it will make it much esier to manuever the wire through.. I also cheat and cut a small hole where I feel the coat hanger poking once it clears inside the door instead of fighting with the mess of wires in there.
-Mike
ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC]
In progess: track down mystery noise <-identified, paint the new dash, get better pic
Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165
Member #995 | My Locker | My New Locker
Catch you next at: ? Auto-X ?
Old 05-06-2009, 08:11 AM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
Couldn't you just tie it to the old wire and pull it through?
