Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Turbo Projects
Old 12-26-2008, 12:45 PM
Twin Turbo EG33
Been playing around with the idea of a twin turbo setup. had some Z32 turbos laying around that I was using for a jig. Still need an external oil return pump and to do all the plumbing... But it is an idle project I have been touching on every once in a while.
Old 12-26-2008, 01:01 PM
Re: Twin Turbo EG33
Bit tight for the oil pan?
I'd always had the thought that the turbos should go in the place of the battery and ABS pump (battery to trunk, non-ABS conversion) with one smaller intercooler in each wheel well.
Old 12-26-2008, 01:09 PM
Re: Twin Turbo EG33
No, the turbos are just sitting there. The flanges I made for the manifolds put them away from the pan but clear everything else....
The further away from the exhaust valves the turbo is, the longer it takes to spool and less efficient they become.
Old 12-26-2008, 01:24 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
Re: Twin Turbo EG33
You know Tom, I always thought that a remote mount setup would work best for a cramped engine bay like the SVX. Unless, of course, there's more space with a manual swap... :|
Old 12-26-2008, 07:49 PM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
Re: Twin Turbo EG33
dito- downside is running the pipes on the awd version. plenty o room to put in the turbos, oil and water lines, not so much on air to intake line.
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 12-26-2008, 08:11 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Twin Turbo EG33
How about building a jig around the engine to simulate the rest of the sheet metal, etc. that would be present if the engine was actually in a car?
Nice start....we'll just want to get closer to this...
knowing that you could always go back to a single turbo...
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-28-2012, 11:05 AM
BackWoodsBob BackWoodsBob is offline
Re: Twin Turbo EG33
GT30r remote mount would work well.
Or twin TD04's in the fog light area with reversed headers.
