Twin Turbo EG33
Been playing around with the idea of a twin turbo setup. had some Z32 turbos laying around that I was using for a jig. Still need an external oil return pump and to do all the plumbing... But it is an idle project I have been touching on every once in a while.
Tom |
Re: Twin Turbo EG33
Bit tight for the oil pan?
I'd always had the thought that the turbos should go in the place of the battery and ABS pump (battery to trunk, non-ABS conversion) with one smaller intercooler in each wheel well.
Re: Twin Turbo EG33
No, the turbos are just sitting there. The flanges I made for the manifolds put them away from the pan but clear everything else....
The further away from the exhaust valves the turbo is, the longer it takes to spool and less efficient they become. Tom |
Re: Twin Turbo EG33
You know Tom, I always thought that a remote mount setup would work best for a cramped engine bay like the SVX. Unless, of course, there's more space with a manual swap... :|
Re: Twin Turbo EG33
dito- downside is running the pipes on the awd version. plenty o room to put in the turbos, oil and water lines, not so much on air to intake line.
David 96LSi 102k Laguna Blue 95 LS-L AWD, Safety package, 140k Polo Green the Chick Magnet: 91 Justy GL EFI 4x4 154k (new motor @120k) 90 Yamaha V-Max 82 Yamaha XJ650LJ Turbo My Diver Propulsion vehicle: 88 Jeep Cherokee 160k "U-sta-have" 88 XT6 AWD Pearl, 86 XT Lt Blue, 85 XT AWD/4x4 Turbo Space Blue |
Re: Twin Turbo EG33
How about building a jig around the engine to simulate the rest of the sheet metal, etc. that would be present if the engine was actually in a car?
Nice start....we'll just want to get closer to this... knowing that you could always go back to a single turbo... -Bill
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 12-26-2008 at 09:07 PM. |
