will 4eat front pinion fit 5mt?
i REALLLLY want to keep my 4.44 gears!
but i also want to swap in a 5mt! i figure the 5mt from something OTHER than a WRX would be the way to go...i understand that the WRX has the front step-down gearing (or step-up?)... but that the other 5mt's do not? (i'm thinking legacy turbo donor car...unless there is a better non-wrx alternative?) the question is: can i yank the front pinion from my 4eat (4.44) and install it (with the rest of the front diff) into a 5mt? indeed...will the 4eat diff even fit in a 5mt at all? or.......... is there a better way for me to achieve 4.44 final drive with a manual transmission? just wondering.....
i'm too svxy for my car rob 92 ebony 4.44's rock !! |
Re: will 4eat front pinion fit 5mt?
Subaru did make some AWD 4.44 manual transmissions.
But the overdrive ratio is higher, making them very high winding. This link should help. http://spda-online.ca/modules/tinyco...ite/tc_28.html
No you cannot use the pinion from an AT w/ an MT
Tom |
thanks tom !!
and thanks svxfiles!! ok then...now the question is: which is "better"....a push type clutch? or pull type...? which is easier/more common to source? the tall 5th gear is no biggie....this is for the rally-beastie... so i'll likely not be using 5th gear anyway (if i do, then i'm going WAAAAAAAAAAYYYY too fast !!!) lol
The Turbo Forester, and Turbo Baja came with a 4.44 MT.....
in the words of c montgomery burns...
"Exxxxcellent!"
regular baja non turbo's have 4.44's too (atleast the 06's do)
Matt 15 OBW premium w/eyesight A picture of an SVX in the garage |
